Brake lines
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
wowens(at)darientel.net
PostPosted: Sun Dec 10, 2006 1:40 pm    Post subject: Brake lines Reply with quote
My quick build RV9A kit appears to be short two flexible brake lines (VA188). Do those come with the finishing kit instead?
Thanks for the guidance on the fuel return system everyone.
Wayne
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
dthomas773(at)sbcglobal.n
PostPosted: Sun Dec 10, 2006 7:12 pm    Post subject: Brake lines Reply with quote
Hi Wayne,
Unless they have changed, flexible brake lines are not
provivded. The instructions will tell you ( at least
mine did )that you use 1/4 inch aluminum tube and
create a half loop at the end and then hook it
directly to the brake. I had a local shop fabricate
18 inch flex lines.
Dennis Thomas
everyone.
Wayne
john castor
PostPosted: Mon Dec 11, 2006 6:14 am    Post subject: Brake lines Reply with quote
Wayne,
I'm at the same placeinstalling brake lines. I have no part labeled VA 188
but do have a VA 118 which came with the finish kit. These lines go from
pedals to firewall connection. My plans also call for aluminum tube from
gear mount to wheel brake. I have considered flexible for this connection.
John Castor
PostPosted: Mon Dec 11, 2006 11:45 am    Post subject: Brake lines Reply with quote
Thanks all.
I called Vans this morning and they told me the brake lines come in the
finishing kit . The fellow who answered my call couldn't understand the
logic of " why the finishing kit not the fuselage kit" either. It sure looks
like it would be easier now than after I have stacked a bunch of aluminum on
top of the pedals.
aurbo(at)ak.net
PostPosted: Mon Dec 11, 2006 12:08 pm    Post subject: Brake lines Reply with quote
Wayne,
If you order the brake lines now don't forget to get the firewall doubler plate. You will still have access to the brake/rudder pedals for a long time but it easier to do now. Don't rivet on the front deck until you are absolutely sure you don't or won't need any more access to the front area.
Mike Ice
RV-9 Wiring, wiring, wiring
gerf(at)gerf.com
PostPosted: Mon Dec 11, 2006 12:29 pm    Post subject: Brake lines Reply with quote
If I were building over again - I would get the finish and FFW
kits at the same time as the fuselage kit - there are a number
of tasks that step on each other if you follow the usual order
emp>wings>fuse>finish>FFW.
g
Thanks all.
It sure looks
of aluminum on
top of the pedals.
aurbo(at)ak.net
PostPosted: Mon Dec 11, 2006 1:46 pm    Post subject: Brake lines Reply with quote
Gerry,
I second your opinion, if space allowed I would want the entire kit ready all at once.
Mike Ice
bill(at)repucci.com
PostPosted: Tue Dec 12, 2006 6:10 am    Post subject: Brake lines Reply with quote
Good advice!
Realizing the brake lines on the -9A are different than on the -9 here
is my experience with the -9.
I did not like the idea of the loop around the brake so I elected to run
the hard line down the gear leg and transition to a 12" section of
stainless steel flex line. Look great, easy enough to do, etc. but...
The fairing would not fit over the union. So, off came those brake
lines and they were replaced with flex lines from the firewall down to
the brake. Much easier installation. I'll post pictures on my web site
in a few days. Busy with work right now.
oliveira(at)frontiernet.n
PostPosted: Wed Dec 13, 2006 2:59 am    Post subject: Brake Lines Reply with quote
The logic on why the finishing kit is really pretty straight
forward. You don't get the brakes themselves until the finishing
kit. You also don't get to the stage where the Gear legs are
installed and you glass the wooden fairing on. that is when you need
the brake line.
I am at the same stage. Installing rudder pedals and wondering how
much to hook up now.
John Oliveira
90054
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
