fuel return lines
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
wowens(at)darientel.net
PostPosted: Fri Dec 08, 2006 5:23 am    Post subject: fuel return lines Reply with quote
How are folks running fuel return lines for fuel injected engines?
Should they go all the way to the fuel tank? do you need a more complex valve that also selects which tank the returned fuel go to.
Thanks for the wisdom.
Wayne
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
Albert Gardner
PostPosted: Fri Dec 08, 2006 8:42 am    Post subject: fuel return lines Reply with quote
Wayne: you can either return fuel to the tank or - in the RV-10 IO-540 engine - we install a T-fitting just after the fuel selector and return fuel there. If you want to return fuel to the tank, some aircraft always return fuel to a specific tank but others use a fuel selector valve that selects a fuel return path at the same time you select a fuel source.
Albert Gardner
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
revenson(at)comcast.net
PostPosted: Fri Dec 08, 2006 9:49 am    Post subject: fuel return lines Reply with quote
trigo(at)mail.telepac.pt
PostPosted: Fri Dec 08, 2006 10:50 am    Post subject: fuel return lines Reply with quote
Wayne
I have a -9A with a Subaru fuel injected engine.
We make the return lines all the way back to each fuel tank, and we use a special 3 way - 2 level fuel valve from Andair. They call it Duplex fuel selector and I used model FS 25- 20.
You can see what is our factory recommended fuel installation here.
If your engine is not a car conversion, you can use the same system, except for the firewall forward part.
Carlos
RV-9A with Egg-Subaru H-6
Portugal
dfischer(at)iserv.net
PostPosted: Sun Dec 10, 2006 1:21 pm    Post subject: fuel return lines Reply with quote
If you're going with a Silverhawk system (Precision/Bendix), I've heard that a return line is not needed. The Airflow Performance system requires a return line, however.
Doug Fischer
RV-9A Wings
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
