haywire(at)telus.net Guest
Posted: Sun Jan 01, 2006 1:58 am Post subject: AoA |
Hi Kevin
Kevin, don't be puzzled , because you're right. It was late and I didn't
feel like getting to in depth about it, but even as I sent it, I knew
somebody would call me on it. I'm certain that you have a better grasp on it
than I ever will, but what I should have said is that the PSS unit directly
measures air pressures on the top & bottom of the wing is actually measuring
the lift being produced, which most people simply refer to as angle of
attack, and lift really is what we want to know. (at least this is how I
understand it). The vane type is the only unit that truly measures angle of
attack directly. I feel that the PSS system is probably the most accurate as
it is measuring the component that is actually keeping us up in the air and
that is lift. I have to be honest and admit that I really don't know exactly
how Dynon is measuring it, but as they only have a single sense line plumbed
to the back of the pitot and then use the pitot $ static inputs, I can only
assume that it is inferential measurement, since they can't be getting any
direct measurement of angle of attack or lift on the wings. In any case, I
have found it to be as accurate as the PSS unit.
Ed, good grief, don't you ever sleep? I thought you already had allot of
projects on the go, now you tell us you're working on an AOA device.
Todd (I hope when I retire I can be as busy as Ed)
HAPPY NEW YEAR TO ALL
eanderson(at)carolina.rr. Guest
Posted: Sun Jan 01, 2006 6:35 am Post subject: AoA |
Yes, Dan. A good article - and if you don't have an extra airspeed
indicator you can order a 2" H20 differential pressure gauge which will also
do the job (and less expensive - as its not an aircraft part)
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
Posted: Sun Jan 01, 2006 6:45 am Post subject: AoA |
Posted: Sun Jan 01, 2006 6:46 am Post subject: AoA |
Hi Dan,
Actually at this point I am using a different probe for the AOA sensing than
the pitot tube. Its basically a bar of aluminum with a port drilled on one
side pointing into the air stream and one on the bottom of the bar This
probe is then mounted at an approx 65 Deg angle to the wing (pointing into
the airflow) so that both ports see the dynamic pressure. Then as AOA
varies - one port sees more/or less of the dynamic pressure component of
interest than the other port giving a pressure differential proportional to
the AOA..
However, my next version will probably be a combination of pitot tube and
AOA probe, it this one the AOA sensing ports will only be 45Deg apart to
make the probe serve as both a pitot pickup and AOA sensor.
I have a heated pitot tube, but had not looked into heating the AOA as I am
a dedicated VFR pilot. But, machining an insert for a heating element might
not be that bad, will have to look into it.
Ed
