vhimsl(at)adelphia.net Guest
Posted: Sat Dec 02, 2006 5:18 pm Post subject: Throttle Bracket VA-149-360-PC experience |
Van’s throttle bracket VA-149-360-PC
RV8 fixed pitch
Aerosport 0-360-a2a
Carburetor: Precision MA-4-5
The bracket works IF you cut off a piece of the corner that hits the engine mount. You will see when you try to attach it to the carburetor.
Use the cut off wheel that you used on your canopy as it makes a much cleaner cut if yours is powder coated like mine.
You will also need to finish drill the carburetor attach bolt holes to 5/16” as the powder coating fills the holes.
Once that is done, the Van’s cables line up perfectly with the carburetor arms and the total look is clean and professional. I am glad I bought it.
Estimated time to trim the bracket is (at) 10 minutes.
Vince H.
RV8 Finish…been that way a very very very long time.
| - The Matronics RV8-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
