Strobes wiring
fstringham
PostPosted: Wed Nov 29, 2006 4:20 pm    Post subject: Strobes wiring Reply with quote
I am in the process of wiring the tail / wing strobes. I have grounded each
wire at the power pack location by bundeling them together and securing them
to the strobe power pack base. Now the ??? At the strobe end should the
ground wire be grounded at this point or taken back to the fairwall ground
block. Also the foil shield does it get any special treatment or just
terminated at each end with no attachment to the airframe.
TIA
Frank (at) SGU and SLC wiring / fiberglassing RV7A
Stay up-to-date with your friends through the Windows Live Spaces friends
list.
nuckollsr(at)cox.net
PostPosted: Wed Nov 29, 2006 9:20 pm    Post subject: Strobes wiring Reply with quote
At 05:18 PM 11/29/2006 -0700, you wrote:
<fstringham(at)hotmail.com>
each wire at the power pack location by bundeling them together and
securing them to the strobe power pack base.
I'm not sure which wires your're referring to.
The cables from each tube assembly are usually 20AWG
twisted trios with a foil shield and drain-wire. You
ground each drain wire to the strobe power supply base.
All other wires ought to drop into pins on connectors
Now the ??? At the strobe end should the ground wire be grounded at this
point or taken back to the fairwall ground block. Also the foil shield
does it get any special treatment or just terminated at each end with no
Nothing attaches to the airframe at the tube end of
each cable. What does the installation drawings
for the strobe system show? The drawings should
be very explicit as to how each conductor in their
system is connected.
< with experiment. >
< --Lawrence M. Krauss >
