hgmckay
Posted: Mon Nov 27, 2006 10:18 am Post subject: SB-912-043-R2 |
Gentlemen: This Rotax SB requires the 50/50 water/glycol coolant temperature to be measured between the engine expansion tank and the radiator. This means that the sending unit must be a type that can be mounted in the coolant line itself in some manner. All the temperature-sending units I have seen are the type that screws into the engine block. Does any one know of a sending unit that can be connected to the coolant line??
<![if !supportEmptyParas]> <![endif]>
Hugh McKay III
912UL
Allegro 2000
N661WW
hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
piercetonypeggy(at)mail.u Guest
Posted: Mon Nov 27, 2006 11:08 am Post subject: SB-912-043-R2 |
Grand Rapids sells an inline sensor that fits in the hose to or from the radiator.
jodel(at)nildram.co.uk Guest
Posted: Mon Nov 27, 2006 11:41 am Post subject: SB-912-043-R2 |
It’s probably on the wrong side of the pond for you, but the UK Rotax distributor sells a complete kit for this.
See http://www.skydrive.co.uk/sd_sa_91.asp
Simon
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Hugh McKay III
Sent: 27 November 2006 18:18
Subject: RotaxEngines-List: SB-912-043-R2
Hugh McKay III
912UL
Allegro 2000
N661WW
hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net) Quote: | www.aeroelectric.com | 0123456789012345
Ollie Washburn
Joined: 10 Jan 2006 Posts: 56 Location: Central Florida
Posted: Mon Nov 27, 2006 12:41 pm Post subject: SB-912-043-R2 |
Grand Rapids Tech. has a piece of tubing that has a fitting welded to it to take a temp probe. The piece of tubing fits in the hose. They also have one with room for a pressure fitting also.
Ollie
_________________ Ollie RV6-A & Rans S7S
Central FL |
Ollie Washburn
Posted: Mon Nov 27, 2006 12:42 pm Post subject: SB-912-043-R2 |
Check Grand Rapids Tech. They have one.
Ollie
Central FL |
