Z-13 for internally regulated alt
steerr(at)bellsouth.net
PostPosted: Mon Nov 27, 2006 5:27 am    Post subject: Z-13 for internally regulated alt Reply with quote
I'm wiring my Zenith 601HD with a Stratus Subaru EA-81 engine using a
modified version of Z-13 - the Generic wiring diagram. Part of the
modification to that diagram is to accomodate the internally regulated
alternator. Z-13 uses a 2-10 Battery/Alt Master switch, so the batter
contacter is engaged in the first On position and both battery and
alternator are connected in the second position, indicating use of a 2-3
switch. I can see an advantage of being able to take the alternator off
line without shutting down the whole system using the 2-10 switch. However,
a note on the wiring diagram for the OVM-14 overvoltage protection module
says both the battery and alternator must come on and go off at the same
time.
Which switch is recommended in this situation? What is the reason for
bringing the battery and alternator on and off together?
Thanks very much for any help or advice.
Bill Steer
PostPosted: Mon Nov 27, 2006 6:07 am    Post subject: Z-13 for internally regulated alt Reply with quote
Oops. That "indicating use of a 2-3 switch" should have been on the
"However" sentence, not the one about the 2-10 switch. Sorry for the
confusion.
nuckollsr(at)cox.net
PostPosted: Mon Nov 27, 2006 6:50 am    Post subject: Z-13 for internally regulated alt Reply with quote
In the early days of the Z-figures and before we had
sources for reasonably priced 2-10 switches, the 2-3
COMBINED with the breaker associated with a crowbar
ov protection system offers both normal operational
control of battery/alternator system (it matters not
whether they are ON/OFF together or progressively
switched OFF/BAT/BAT+ALT). The pullable breaker
offers a means by which an alternator can be kept
quiet on the ground during battery only ops.
You can use either combination but know also that
many if not all internally regulated alternators cannot
be shut down from outside should the regulator fail
in a ov runaway condition. A system for offsetting that
feature was published in the 'Connection some years ago
(Figure Z-24 combined a b-lead contactor and OVM-14).
Mis-use of this architecture (operating the alternator
ON/OFF control while alternator was under load) precipitated
some damage to alternator regulators. The word went out
that the circuit was "flawed and not recommended." One
can debate the politics of this statement endlessly but
the bottom line is that I withdrew Z-24 in its original
form.
A new control philosophy is being explored that will
offset the shortcomings of the original Z-24. See:
http://www.aeroelectric.com/PPS/DCPwr/OV/z24a_Preliminary.pdf
It's by belief that this product will allow any time, any
conditions, ON/OFF control of an IR alternator without regard
to system safety.
Short answer to your question is that I recommend the 2-10
switch because it integrates nicely with the proposed
9004-1 Controller. But if you install a 2-3, the system will
come on line and function as advertised but without the
ability to control the alternator at will.
However, a note on the wiring diagram for the OVM-14 overvoltage
protection module says both the battery and alternator must come on and go
off at the same time.
Where do you find this? I'm trying to understand the
context of the statement, at the moment it doesn't
seem valid . . .
You can go either way but the 2-10 is recommended for
the reason cite . . .
PostPosted: Mon Nov 27, 2006 7:52 am    Post subject: Z-13 for internally regulated alt Reply with quote
Thanks, Bob. I'll certainly go with your recommendation for the 2-10.
To answer your question about the source of the statement that said the
battery and alt must come on and off together... The OVM-14 from B&C came
with two wiring diagrams enclosed - one for internally and one for
externally regulated alternators. Both diagrams have a statement that says
"IMPORTANT - BATTERY CONTACTOR AND ALTERNATOR SHOULD COME ON AND OFF
TOGETHER."
<snip>
seem valid . . .
PostPosted: Mon Nov 27, 2006 10:06 am    Post subject: Z-13 for internally regulated alt Reply with quote
says "IMPORTANT - BATTERY CONTACTOR AND ALTERNATOR SHOULD COME ON AND OFF
TOGETHER."\
Hmmm . . . okay. That doesn't appear in one of
my publications. Thanks!
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
