Icom A200 - Question for Stein
nuckollsr(at)cox.net
PostPosted: Mon Nov 27, 2006 2:38 am    Post subject: Icom A200 - Question for Stein Reply with quote
At 10:42 PM 11/25/2006 -0800, you wrote:
I've been informed by a number of people that the A200 is identical design
to the BendixKing KY96. it certainly seems functionally identical and I
recall the trays fit each other's radio. Bob, if you do get that
icom manual pse confirm ? I'm a radio tech and got some of the BK manual
from the avionics dealers (they quite rightly weren't keen to give me the
whole manual) every time i'm asked to set up an A200 I just do as I have
for the BK. The mod. level adjust pot works backwards too, just like the
original- talk about attention to detail!
Therefore any wiring setup used for the BK hot mic intercom should apply
to the A200.
I presume you're asking me about this issue. I've
not dabbled in the details of the various radios
for about 20 years and those radios were the kinds
of systems that go into the big GA aircraft.
So aside from a bit of interconnect data left over
from a bygone era of my career, I no longer have
access to or posses current knowledge of the details
you're asking about.
The honorable Stein Bruch might be your best
bet for answering this question. Stein, can
you help us out here?
