hgmckay
Posted: Sat Nov 25, 2006 6:18 am Post subject: Service Bulletin SB-912-043 R2 |
Gentlemen:
<![if !supportEmptyParas]> <![endif]>
If you have a Rotax 912UL and you are using 50/50 water/glycol coolant you need to read this SB and the accompanying explanation. Do any of you know where one can get the “sensor” and “gauge” required by this Bulletin?
Hugh McKay
Allegro 2000
N661WW
hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Sjklerks(at)aol.com Guest
Posted: Sat Nov 25, 2006 1:52 pm Post subject: Service Bulletin SB-912-043 R2 |
Hi Hugh, I don't know if John has any thing, but Rans aircraft has a Tee fitting that the water temp probe fits into. I mounted mine between the tank and alum tube. Works great
Jim
IV- 912
Thom Riddle
Posted: Sun Nov 26, 2006 5:18 am Post subject: Service Bulletin SB-912-043 R2 |
Wicks Aircraft Supply has a TSO'd 2 1/4" Westach water temperature
gauge and sender complete for $100. A good bit less than the UMA
instruments (non-TSO'd) at Aircraft Spruce.
http://www.wicksaircraft.com/catalog/product_cat.php/subid 758/
index.html
Thom in Buffalo
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
