gmcjetpilot(at)yahoo.com Guest
Posted: Sat Jan 28, 2006 6:44 am Post subject: Why use starter contactor (fire) |
Quote: | From: sportav8r(at)aol.com wrote
>I don't think the hot wire to the starter is to worry about, since it is
Quote: | controllable via the battery contactor in event of smelling smoke... not
perfect protection but at least control.
-Bill B
Good point, I agree. I stated:
"The only down side is that 3-4 foot length of 2-4 AWG is hot all the time
the master is on".
If the master is off before impact it's a moot point, but light airplanes are
notoriously not cash worthy. The steel tube frame is best, aluminum
semi- monoquoque structure is OK, but as a RV builder the fuselage is
not that robust. However the beauty of the RV is integral wing tanks
outside the cockpit and slow stall. Fiberglass / composites, are one of
the worst. It does not deform or yield to absorb energy. It strains and than
ruptures like an egg. As far as fire any plane that has fuel in the cockpit
is at risk of being a future weenie roast.
>Dave Morris WROTE:
Quote: |
This happened to a friend of mine who would have walked away from a
crash if it had not been for that one little spark.
Your comments about skin graph are quite graphic. Sorry to hear about
your friend but I don't think the fat starter cable would have made a
difference. He had fuel and a spark, what would another spark have
mattered. Besides as Bob, sportav8 pointed out, the master relay will
eliminate the issue all together if you turn it off, but it does not matter, if
you are comfortable with the FW contactor than put one on. I am just no
convinced it will eliminate the chance of fire significantly. If you look at
firewalls of RV's with big bare copper straps and fuse blocks all cluster
just a foot or so away from the gascolator does not give me warm
fuzziness. I guess the best defense is practice you emergency forced
landing procedures and remember to turn the fuel and electrics off before
the ground smite ye mightily.
Quote: | What's a few bucks, guys? My experience with this friend of mine has made
me a believer in steel braided fuel hose, Earl's fittings, Nomex clothing,
and a lot of other things that may cost a few dollars extra, but could
avoid years of skin graft surgery.
I would suggest the heavy duty integral fire sleeve (brown) fuel lines from
StratoFlex or Aeroequip. I don't think Earls' has that? Also an aerospace
quality hose, if you are worried about fuel leaks and fire, should be made by
an approved shop. It cost a lot more than Earl's, and as you say what's a
few extra dollars. Also Nomex and helmets and gloves are all good stuff.
Bird strikes are deadly in fast homebuilts with thin plexiglass windows. The
window on the 757 I fly has multi-panes and very thick. The 250 kts limit
below 10,000 feet is in part for bird strike. I had one and it shattered the
windscreen. It happened at 9,000 feet! It held. So I expect to see you with
a helmet and eye protection and a nomex flight suite going fast Dave.
George
rv8ch
Posted: Sat Jan 28, 2006 7:41 am Post subject: Why use starter contactor (fire) |
Quote: | Bird strikes are deadly in fast homebuilts with thin plexiglass windows.
... So I expect to see you with
Although I know it would be a good idea, I just can't see
myself flying around with a helmet in an RV without getting
paid. However, speaking of eye protection, can anyone
recommend some good eye protection in case of a bird strike?
In keeping with the spirit of this list, they can be
wired to the airplane electric system, battery operated,
or unpowered.
Thanks!
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
Gilles.Thesee(at)ac-greno Guest
Posted: Sat Jan 28, 2006 7:52 am Post subject: Why use starter contactor (fire) |
Mickey Coggins a crit :
Hi all,
Fighter pilots always fly with visor down.
My friends warbird pilots fly with nomex suits and crash helmets.
Gilles Thesee
Grenoble, France
http://contrails.free.fr
VE3LVO(at)rac.ca Guest
Posted: Sat Jan 28, 2006 12:54 pm Post subject: Why use starter contactor (fire) |
from
by
The
the
with
George
Also - You turn on the landing lights below ten for the same reason - birds.
Cheers, Ferg
