CJ6A - overvoltage module update
brian
PostPosted: Sat Jan 28, 2006 8:06 am    Post subject: CJ6A - overvoltage module update Reply with quote
Bob is putting together a kit for the over-voltage protection module and
had a question that I thought I would direct to all of you.
The module has two status lamps, one for low-voltage, one for
over-voltage trip, and a test/reset button. Would those of you who are
interested in this module please let me know if you would like the kit
to include a labeled placard along with the bulb holders, bulbs, and the
push-to-test/reset button.
I have attached a PDF of what the placard would look like.
BTW, the largest part is the relay. The actual circuit module is only
about twice the size of the DB-9 connector used for all the wiring. (A
DB-9 connector is the type used on PC serial ports in case you are
wondering how big that is.)
I still need to find a CJ6A with a stock generator here in central
California to use as a test bed. The wiring changes are very small, just
get power from the bus and break the field wire somewhere to insert the
relay. If you don't want to keep the module for some reason it would
only require one splice to put everything back the way it was.
BTW, Bob will not release the kit until it has been flight-tested. He
doesn't believe in "vaporware" products that promise and then don't deliver.
Brian Lloyd 2243 Cattle Dr.
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
9011-301-1_Placard.pdf
 Filename:  9011-301-1_Placard.pdf
 Filesize:  28.65 KB
 Downloaded:  730 Time(s)
Brian Lloyd
wlannon(at)cablerocket.co
PostPosted: Sat Jan 28, 2006 10:13 am    Post subject: CJ6A - overvoltage module update Reply with quote
Hi Brian;
Great progress. I hope you can find someone in your area to with a stock
generator control CJ to help out with the testing.
Am I correct in assuming the indicator panel is separate from the actual
unit? If so I would personally not require that since I have a stock of MS
style PTT warning lights, switches and facilities for placard manufacture.
All I would need is instructions to hook it all up.
If you can give exact dimensions for the placard I will make some for you at
no charge. These would be made from 1/32" or .020" engraving plastic and I
will install attaching adhesive tape.
Cheers;
Walt
brian
PostPosted: Sat Jan 28, 2006 10:41 am    Post subject: CJ6A - overvoltage module update Reply with quote
Walter Lannon wrote:
Yak-List message posted by: "Walter Lannon" <wlannon(at)cablerocket.com>
Hi Brian;
stock generator control CJ to help out with the testing.
Here's hoping. There are a couple around I haven't approached directly yet.
actual unit?
Yes. The module itself is smaller than 1" square. The relay, its socket,
and associated parts, are only slightly larger than that.
manufacture. All I would need is instructions to hook it all up.
No problem.
you at no charge. These would be made from 1/32" or .020" engraving
plastic and I will install attaching adhesive tape.
Well, Bob is kitting up the whole thing so it comes with all parts and
instructions. He is aware that the CJ6A already has a low-voltage
indicator (the red "generator" light) but he also plans to use this
module for other aircraft. You probably ought to make your offer
directly to Bob ("nuckollsr at cox dot net").
So I do need a good idea as to the desirability of the "control panel".
Brian Lloyd
Frank
PostPosted: Sat Jan 28, 2006 12:08 pm    Post subject: CJ6A - overvoltage module update Reply with quote
Look good to me, Brian.
Frank
