Anybody There?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Jabiru-List
jimlc(at)att.net
PostPosted: Sun Oct 29, 2006 7:03 pm    Post subject: Anybody There? Reply with quote
I joined this list after I ordered the 3300A Jabiru firewall forward
package as a replacement for my NSI turbo CAP Sabaru engine package
on my Kitfox Series 5. As best I can tell I have never received a
message posted by a member of this list. Am I the only member?
Receiving only a small portion of the emails I receive on the Kitfox
List is a relief, but to never receive one in over a month is another
thing. Smile
Jim Crowder
- The Matronics Jabiru-List Email Forum -
http://www.matronics.com/Navigator?Jabiru-List
xl(at)prosody.org
PostPosted: Sun Oct 29, 2006 10:46 pm    Post subject: Anybody There? Reply with quote
There appears to be very little traffic on this list.
Have you cleaned your carburator lately???
(Should be in the maintenance call outs........)
Joe E
N633Z (at) BFI
CH601XL 402 hours
Jabiru 3300, Sensenich 64x49 wood prop
thing. Smile
Jim Crowder
jimlc(at)att.net
PostPosted: Mon Oct 30, 2006 11:24 am    Post subject: Anybody There? Reply with quote
Joe,
I will not receive my engine until late February as per their
acknowledgement. I was told when I ordered it that since they had
added hydraulic valve lifters to the engine, there had been a surge
in orders and a push out in delivery times. So no I have not cleaned
my carburetor. What is the story behind this? How do you like your
engine? How long have you had it? Is there anything else you can
tell me? What can you tell me about its performance? Where are you
located? I have had little owner feedback up until now and am
starved for information.
Many thanks,
Jim Crowder
Loveland, CO
Joe E
N633Z (at) BFI
CH601XL 402 hours
xl(at)prosody.org
PostPosted: Mon Oct 30, 2006 10:59 pm    Post subject: Anybody There? Reply with quote
I've been flying 633Z since April 2004.
I don't have the hydraulic lifters so every 50 hours I check the valve
clearance. I check the head bolt + prop bolt torque at the same time.
The engine runs smooth + strong. I've taken a bunch of fellow 601XL
builders + prospective builders along and they like it too.
I had a couple of instances of rough running on takeoff and one during
a climb at 2000 feet. I grounded the plane after that one and didn't
make the Zenith Cooperstown CA (I think) flyin. I removed and cleaned
the carburetor that weekend. The slide position is controlled by vacuum.
And the rubber bellows provides the resistance and return force.
When I moved the slide with my finger I noted rough spots near idle and
near full throttle - where the slide spends most of its time. I used
carburetor cleaner liberally to remove the dark deposits. And the slide
moved freely in all positions.
I've flown about 5 hours since then and the engine runs more smoothly at
idle and at cruise. The contamination built up slowly in the carburetor
and I didn't notice the change - except for the stumbles, and I didn't
like those a bit. I am confident that I found the problem. I ruled out
other causes.
Now that I know what the symptoms of carburetor buildup are I'll clean
the carburetor when I notice them or every annual - which ever comes
first. I took another look at my copy of the Jabiru maintenance manual
and I see no mention of this critical maintenance item.
I tried the yahoo groups - yuk. If no one posts on this group, I'll miss
out. But, I don't like the yahoo groups site.
Joe E
633Z (at) BFI
On Mon, 30 Oct 2006, Jim Crowder wrote:
Joe,
Jim Crowder
Loveland, CO
>Joe E
>N633Z (at) BFI
>CH601XL 402 hours
jimlc(at)att.net
PostPosted: Mon Oct 30, 2006 11:13 pm    Post subject: Anybody There? Reply with quote
Joe,
Thanks for the reply. I will remember your experience and stay
posted to the list.
Jim Crowder
Loveland, CO
other causes.
Joe E
633Z (at) BFI
> Joe,
> Jim Crowder
> Loveland, CO
> >Joe E
> >N633Z (at) BFI
> >CH601XL 402 hours
deuskid
PostPosted: Tue Oct 31, 2006 3:30 am    Post subject: Re: Anybody There? Reply with quote
I'm here because I'm considering a Lightning with a 3300 but these were the first posts presented since I joined this list.
Kind of library quiet around here.... Very Happy
CHMIK(at)aol.com
PostPosted: Tue Oct 31, 2006 6:57 am    Post subject: Anybody There? Reply with quote
Jim, I monitor the site and have never seen any traffic....I plan to put a Jabiru on my Lightning when the kit is delivered and I finish it. I, like you, wonder if anyone has been responding or is the Jabiru-list not funcitioning..charlie keith (KFKN). [quote][b]
kensmith(at)springnet1.co
PostPosted: Tue Oct 31, 2006 6:58 am    Post subject: Anybody There? Reply with quote
What Type (auto fuel or aviation fuel), what Brand and what Octane fuel were you using
when the rough engine problems occured?
Jim Crowder wrote:
--> Jabiru-List message posted by: Jim Crowder <jimlc(at)att.net> (jimlc(at)att.net)
Joe,
Thanks for the reply. I will remember your experience and stay posted to the list.
Jim Crowder
Loveland, CO
--> Jabiru-List message posted by: xl <xl(at)prosody.org> (xl(at)prosody.org)
other causes.
Joe E
633Z (at) BFI
> Joe,
> Jim Crowder
> Loveland, CO
> >Joe E
> >N633Z (at) BFI
> >CH601XL 402 hours
andy(at)suncoastjabiru.co
PostPosted: Tue Oct 31, 2006 7:32 am    Post subject: Anybody There? Reply with quote
Charlie,
We started the list as a USA Jabiru aircraft kits distributor, and with some 20 aircraft built under our supervision we are happy to provide both advice and comments about Jabiru aircraft where possible. It’s true there hasn’t been much activity but let’s hope more Jabiru owners / builder join and get involved!
For those seeking information about Jabiru engines for operation in non-Jabiru aircraft, please visit the Matronics Jabiru Engine List at http://forums.matronics.com/viewforum.php?f=29&sid=73595155690d945abfb1907109795baa
We’ll do our best on both lists to help where needed.
Andy Silvester
Suncoast Sportplanes, Inc.
39248 South Ave. Zephyrhills, FL 33542
Tel: 813 779 2324 Fax: 813 779 2246
www.suncoastjabiru.com
Snow_Board(at)cox.net
PostPosted: Tue Oct 31, 2006 6:03 pm    Post subject: Anybody There? Reply with quote
Hello All,
I'm new to the list and trying to learn the ins & outs of the Jabiru 3.0l
engines.
L David Stricker
PostPosted: Tue Oct 31, 2006 6:10 pm    Post subject: Anybody There? Reply with quote
Hello John,
Same here. I saw the one at CopperState and was very impressed.
Planning on a demo ride later in November.
L David Stricker
Goodyear AZ
xl(at)prosody.org
PostPosted: Tue Oct 31, 2006 10:45 pm    Post subject: Anybody There? Reply with quote
- 100LL
- new plugs
- new air cleaner
- new fuel filter
- carb heat on
- electric boost pump on
- recent oil change
- recent valve clearance check
- stumble during climb at ~2000'
- clean carburator
- noticable improvement in performance, during ~5 hours of flight
- smoother at idle
- smoother at cruise
- hopefully no more stumbles - time will tell
Joe E
N633Z (at) BFI
CH601XL, 404 hours
were you using
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Jabiru-List All times are GMT - 8 Hours
