EGT/CHT thermocouple cable
JohnT(at)comp-sol.com
PostPosted: Tue Jan 24, 2006 1:30 pm    Post subject: EGT/CHT thermocouple cable Reply with quote
Does anyone know of a source for twisted pair stranded non sheathed J &
K thermocouple cable (extension grade is fine)- with tefzel insulation?
Also what is being used to provide connect/disconnect capability?
nuckollsr(at)cox.net
PostPosted: Tue Jan 24, 2006 1:46 pm    Post subject: EGT/CHT thermocouple cable Reply with quote
http://www.omega.com/pptst/EXGG_JX_WIRE.html
http://www.omega.com/pptst/EXGG_KX_WIRE.html
http://www.omega.com/pptst/GMP.html
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
rd2(at)evenlink.com
PostPosted: Tue Jan 24, 2006 2:41 pm    Post subject: EGT/CHT thermocouple cable Reply with quote
I didn't ask the question, but was about to.
Thanks, Bob!
Rumen
_____________________Original message __________________________
(received from Robert L. Nuckolls, III; Date: 03:45 PM
1/24/2006 -0600)
<nuckollsr(at)cox.net>
aadamson(at)highrf.com
PostPosted: Tue Jan 24, 2006 3:35 pm    Post subject: EGT/CHT thermocouple cable Reply with quote
Mcmaster carr also carries these. Page 527 of the current website or search
for thermocouple wire. I didn't check to see who's prices were cheaper.
Alan
wschertz(at)ispwest.com
PostPosted: Tue Jan 24, 2006 3:36 pm    Post subject: EGT/CHT thermocouple cable Reply with quote
McMaster Carr
Bill Schertz
KIS Cruiser # 4045
sportav8r(at)aol.com
PostPosted: Wed Jan 25, 2006 8:31 am    Post subject: EGT/CHT thermocouple cable Reply with quote
Wonder why they don't list J-type male connectors?
-Bill B
PostPosted: Wed Jan 25, 2006 8:50 am    Post subject: EGT/CHT thermocouple cable Reply with quote
-Bill B
Go to the Part Number Builder box further down and
it will let you order a GMP-J-M for $2.50.
PostPosted: Wed Jan 25, 2006 6:47 pm    Post subject: EGT/CHT thermocouple cable Reply with quote
I didn't see that; thanks for pointing it out.
Don't I recall from somewhere that it's okay to use, say, crimp-on molex pins on the appropriate extension wires, as long as a certain symmetry of junctions in the cable run is maintained? I think that's how i extended by GRT probe wires ages ago, and it _seems_ to work okay.
-Bill
PostPosted: Thu Jan 26, 2006 4:59 am    Post subject: EGT/CHT thermocouple cable Reply with quote
As long as your T/C wires are 20 or 22AWG, you can run them through
ordinary D-sub connectors . . . SOLID MACHINED pins preferred. While
the pins for a D-sub are NOT identical to the thermocouple wires being
joined, they insert a pair of equal but opposing parasitic thermocouples
into both leadwires. The parasitic thermocouples cancel each other out
because they are in such close proximity to each other and have a common
local temperature.
recapen(at)earthlink.net
PostPosted: Thu Jan 26, 2006 6:23 am    Post subject: EGT/CHT thermocouple cable Reply with quote
From an earlier post, I understood that this would not be applicable to a firewall situation as the temperatures are different on either side of the firewall.
Somebody keep me honest here........
PostPosted: Thu Jan 26, 2006 7:06 am    Post subject: EGT/CHT thermocouple cable Reply with quote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==
cjensen(at)dts9000.com
PostPosted: Thu Jan 26, 2006 7:35 am    Post subject: EGT/CHT thermocouple cable Reply with quote
John,
You mustr have a bad ground or your RF interference is something else!!!
Chuck Jensen
PostPosted: Thu Jan 26, 2006 8:14 am    Post subject: EGT/CHT thermocouple cable Reply with quote
The cable referenced is not Tefzel insulated. The have Teflon PFA (Perfluoroalkoxy) or FEP (Fluorinated Ethylene Propylene). Tefzel is ETFE (Ethylne TriFluoroEthylene).
Also - note that the only stranded wire listed in this reference is PVC.
I called Omega and talked with John Bach (I think he is in pre-sales support) and he said they don't make thermocouple wire with Tefzel insulation. I could custom order if 25K ft or more was needed Surprised). He's a nice guy and suggested: http://www.omega.com/pptst/TFIR_CH_CI_CC_CY_AL.html It's not stranded either.
McMasterr-Carr on Pg 527 per Alan K. Adamson's post.... does sell FEP stranded type J & K in 20awg. I don't know if it's twisted however.
I'll contact Omega again - appreciate any other insights.
BTW - Omega sells Sub-D type thermocouple alloy pins and sockets. http://www.omega.com/ppt/pptsc.asp?ref=SM_SUB-D_CONN&Nav=temg12
Time: 01:46:05 PM PST US
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: EGT/CHT thermocouple cable
PostPosted: Thu Jan 26, 2006 10:37 am    Post subject: EGT/CHT thermocouple cable Reply with quote
At 09:22 AM 1/26/2006 -0500, you wrote:
<recapen(at)earthlink.net>
the firewall.
We're talking apples and oranges here.
(1) D-subs can be a useful means for providing
convenience disconnects in thermocouple lines.
(2) D-subs are not suitable for firewall penetrations.
You can use a d-sub either forward or aft of
a protected penetration, just don't depend on
it for BOTH convenience disconnect AND
protected penetration.
PostPosted: Thu Jan 26, 2006 10:50 am    Post subject: EGT/CHT thermocouple cable Reply with quote
Thanks - I knew there was a reason I wasn't gonna do it that way........
Worth the price of my list donation once again........
