Rear canopy installation
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
rock5219
PostPosted: Tue Oct 24, 2006 7:20 pm    Post subject: Rear canopy installation Reply with quote
Greetings I think I have made a major screw up. I riveted the turtle deck on many months ago, and now that I am ready to install the rear canopy, it appears that, according to instructions, I must drill out the 200+ rivets and remove it. Is it possible to install the rear canopy without taking the turtledeck off? DUH! Randy Embarassed
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
aurbo(at)ak.net
PostPosted: Wed Oct 25, 2006 5:08 am    Post subject: Rear canopy installation Reply with quote
Randy,
I saw your post and was hoping someone would jump in with an answer. I have
riveted on the rear deck and am just about to start on the canopy. so you
can see I am interested in what ever you find out.
Why do you think you have to drill out and remove the rear deck?
If you don't get any responses on this list try the Doug Reeve's Van's Air
Force web site. Or if you don't want to do that or can't I will do it for
you if you don't mind.
Mike Ice
RV-9 (working on electrical, waiting for canopy)
Anchorage, Alaska
rock5219
PostPosted: Wed Oct 25, 2006 5:18 am    Post subject: Re: Rear canopy installation Reply with quote
Installation manual talks of removing the turtledeck and doing layouts with it as well as for fitting. I did receive 1 response offline that said that while it may be slightly more difficult, he did not feel it was necessarily required. Still waiting to see if anyone has completed this procedure. Thanks, Randy
bill(at)repucci.com
PostPosted: Wed Oct 25, 2006 5:52 am    Post subject: Rear canopy installation Reply with quote
Randy (and Mike),
I'm assuming you are talking about a tip-up canopy. If not, this won't
help you much.
I did not rivet that skin on until the aft canopy was trimmed but all is
not lost. Just drill out the rivets along the sides until you can pull
the skin away, say maybe 12 to 18" worth. That should give you enough
play to slide the canopy in.
Good luck.
Starting the paper work but sill have a lot left to do.
aurbo(at)ak.net
PostPosted: Wed Oct 25, 2006 6:01 am    Post subject: Rear canopy installation Reply with quote
Bill, (Randy)
Ahh! Good on you. I forgot to ask the simple question if the chap was
building a slider or tip up.
Which is it Randy? Bill is building a tip up and I am doing a slider. Bill
has an excellent web site and has been a constant resource for me.
Bill, your work looks great, you will be flying soon.
bill(at)repucci.com
PostPosted: Wed Oct 25, 2006 7:14 am    Post subject: Rear canopy installation Reply with quote
Mike,
Thanks for the complements. If, and I do mean IF, I get it done before
spring a bunch of us are talking about flying up to AK in July. I'll
let you know how and if that happens.
BTW, how is it we have a Michale Ice and a Daniel Snow on the same list?
RV-9 N941WR
www.repucci.com/bill/baf.html
rock5219
PostPosted: Wed Oct 25, 2006 7:29 am    Post subject: Re: Rear canopy installation Reply with quote
I am building the tip-up version. Randy
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
