Cellphones in the air
N6030X(at)DaveMorris.com
PostPosted: Mon Oct 23, 2006 6:25 pm    Post subject: Cellphones in the air Reply with quote
I've tried to use my Verizon (CDMA) cellphone on several flights now,
well within coverage areas, with good signal strength, from 3500 feet
to as high as 8500 feet in line of sight and close to - or over -
plenty of civilization. It never works.
I'll have as many as 5 bars showing, but they are changing rapidly
from no bars to 3 bars to 5 bars, dancing all around.
What happens is that I dial the number, it spends a few seconds
longer than normal connecting, and then either connects for a split
second, or doesn't connect at all, but in either case it pops up a
message saying "Signal Lost" and disconnects.
Is anybody on this list able to reliably use a cellphone from in your airplane?
Dave Morris
1960 Mooney M20A
N6030X at 52F
ainut(at)hiwaay.net
PostPosted: Mon Oct 23, 2006 6:55 pm    Post subject: Cellphones in the air Reply with quote
That used to be illegal -- might still be. Old cells would tie in with
any tower they could see and from an airplane they could see a lot,
causing jamming to the cell system.
David M.
Dave N6030X wrote:
<N6030X(at)DaveMorris.com>
What happens is that I dial the number, it spends a few seconds longer
than normal connecting, and then either connects for a split second,
or doesn't connect at all, but in either case it pops up a message
airplane?
Dave Morris
1960 Mooney M20A
N6030X at 52F
sportav8r(at)gmail.com
PostPosted: Mon Oct 23, 2006 7:35 pm    Post subject: Cellphones in the air Reply with quote
With analog phones, if you can still find one, it is illegal. He
specified CMDA; the old rules seem not to apply to this service. As
PIC, he certifies what is legal in his airplane as far as interference
risks to safety of flight.
My experience has been that down low, the reception is fine. Up high,
it is as described - very frustrating. Text messages still work when
voice won't, often. Perhaps the downward tilt of the antenna lobes on
the cell towers. It's been discussed in the archives, but I'll wait
to see if any new info surfaces this time around Wink
-Bill B
David M.
> airplane?
> Thanks,
> Dave Morris
> 1960 Mooney M20A
> N6030X at 52F
LarryRosen
PostPosted: Tue Oct 24, 2006 4:05 am    Post subject: Cellphones in the air Reply with quote
It is an FTC regulation that prohibits the use of cell phones in
airplanes, not an FAA regulation.
Larry
Bill Boyd wrote:
<sportav8r(at)gmail.com>
-Bill B
> David M.
> > airplane?
> > Thanks,
> > Dave Morris
> > 1960 Mooney M20A
> > N6030X at 52F
Larry Rosen
#40356
N205EN (reserved)
<http>
nuckollsr(at)cox.net
PostPosted: Tue Oct 24, 2006 5:16 am    Post subject: Cellphones in the air Reply with quote
At 09:22 PM 10/23/2006 -0500, you wrote:
I've tried to use my Verizon (CDMA) cellphone on several flights now, well
within coverage areas, with good signal strength, from 3500 feet to as
high as 8500 feet in line of sight and close to - or over - plenty of
I'll have as many as 5 bars showing, but they are changing rapidly from no
than normal connecting, and then either connects for a split second, or
doesn't connect at all, but in either case it pops up a message saying
airplane?
The old "cell" phone technology used some site-selection
philosophies based on signal strength. It was assumed that
when a phone was in use, it would be in range of perhaps
a half-dozen adjacent antenna sites and they would talk
amongst themselves to decide who would service the call
and which adjacent cell would take over if the phone was
moving.
Accessing these systems from the air might cause dozens
of sites to get pinged and the site swap algorithm would
get overloaded.
The digital systems are much more agile. I suspect that
when your phone requests service now, the system deduces
when you're airborne and simply locks you out. I've
tried several brands of mobile phones from inside airplanes
at all altitudes with very mixed results . . . mostly
poor.
If 9-11 happened today, it's much less likely that folks
within a hijacked aircraft would be able to establish
useful communications with the ground via hand-held
phones.
PostPosted: Tue Oct 24, 2006 5:29 am    Post subject: Cellphones in the air Reply with quote
It's my understanding that CDMA devices are not prohibited from such
use, but that's from prior discussions here years back. Do you have
"chapter and verse" to share with us? I for one would like to stay
current on this topic, as I do use my cell phone aloft from time to
time (and as I said, down low, below 2000AGL, usually with success.)
-BB
Larry
> -Bill B
>> David M.
>> > airplane?
>> > Thanks,
>> > Dave Morris
>> > 1960 Mooney M20A
>> > N6030X at 52F
kayce33(at)earthlink.net
PostPosted: Tue Oct 24, 2006 5:40 am    Post subject: Cellphones in the air Reply with quote
I believe the FCC does not allow cell use in flight.
Harold
rvbuilder(at)sausen.net
PostPosted: Tue Oct 24, 2006 6:25 am    Post subject: Cellphones in the air Reply with quote
I think we spend more time discussing off-topic stuff nowadays. Seems
like I'm deleting 90% of what is posted.
http://www.fcc.gov/cgb/consumerfacts/cellonplanes.html <- Horses mouth
Now, can we stick with aircraft electrical systems.
PostPosted: Tue Oct 24, 2006 8:02 am    Post subject: Cellphones in the air Reply with quote
I know all about the legalities, having studied both the FAA and the
FCC regs on the matter, and also having read the archives and
discussed it with a few experts off-list.
I was more curious about the practicality, i.e. whether people were
ABLE to make connections via cell phones. If not, and if there are
no rules against making calls in my Verizon contract, then it would
seem that Verizon is illegally impeding my use of my cellphone just
because I'm in the air, and I need to find out why.
Thanks to those of you who generally agreed that you can make calls
from down low, but not from up high.
Dave Morris
P.S. This is an RF issue, which falls under the science of
electromagnetism, and thus IMHO included in the mission of this list.
At 08:39 AM 10/24/2006, you wrote:
<kayce33(at)earthlink.net>
Harold
mprather(at)spro.net
PostPosted: Tue Oct 24, 2006 11:22 am    Post subject: Cellphones in the air Reply with quote
A few comments:
In some places, I have had a very easy time using my GSM phone while in
flight as high as 5000' AGL. Because the terrain around here is so high,
I can't recall trying to use the phone while above that altitude.
In urban areas (while flying), I think my luck is not as good. It's
possible that while in flight we get locked out when in areas where user
density demands high tower density. Handsets used in flight over an urban
area can see MANY more towers than when over sparsely populated areas.
Verizon may not be deliberatly excluding flying subscribers so much as
using antenna systems which concentrate on reliably communicating with
ground based ones. By doing this they can use fewer towers and/or lower
powered transmitters while providing at least as good coverage. I would
suspect that Verizon's coverage maps are modeled with ground based users
in mind.
Matt-
Dave Morris
>Harold
