GRT/Lightspeed/Mags
aaaron(at)tvp.com.au
PostPosted: Mon Jan 23, 2006 11:52 pm    Post subject: GRT/Lightspeed/Mags Reply with quote
Hi all
I have a GRT EIS 4000 and one lightspeed plasma III in my MustangII. I
was going to take the tach signal from the lightspeed but did some web
surfing and have come to the conclusion that it would be better to take
the signal from the P-lead since that way, it would be obvious if the
mag dies (no rpm signal) whereas if the lightspeed dies it will be
obvious because of the rpm drop. Is this the right approach? I don't
want to have to wire another switch in the panel.
Second, related question ... I'm using single shielded wire for the
p-lead. Core goes to the contact inside the ferrule (or whatever its
called). I've attached a pigtail to the shield and bolted that to one of
the 4 m/c screws that attached the HT leads. Is this the right
approach?
Thanks in advance
Allan
nuckollsr(at)cox.net
PostPosted: Tue Jan 24, 2006 11:11 am    Post subject: GRT/Lightspeed/Mags Reply with quote
At 06:50 PM 1/24/2006 +1100, you wrote:
Hi all
It doesn't make much difference. RPM displays have almost
zero significance in effecting a no-sweat termination of
flight. Do whatever is easiest and lowest risk for noise
propagation. I'd tie it to the electronic tach output from
the electronic ignition.
approach?
Yes.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
http://www.aeroelectric.com
