Linux CAD Options (was: Re: Turbocad)
dwight(at)openweave.org
PostPosted: Tue Jan 24, 2006 8:29 am    Post subject: Linux CAD Options (was: Re: Turbocad) Reply with quote
Dan,
I've used Qcad and found a program called 'dwg2dxf' that will convert
the DWG to DXF. Works great. You can find it at :
https://sourceforge.net/project/showfiles.php?group_id=30996
There are multiple items you can download there, but the second entry
is entitled "DWG to DXF" and has a "dwg2dxf-2.1.tar.gz" that you can
pull down. Get it, unbundle it, build it, and start converting.
-- Dwight
On Sat Jan 21 22:04:42 2006, Dan O'Brien wrote :
Has anyone found a CAD program that works with Linux? I still have a
Windows boot on which I can use Intellicad quite effectively, but I dual
boot Linux and would like a Linux CAD program capable of reading dwg files.
There is one that does dxf files (it's called QCad), but I don't know of a
reasonably priced Linux variant that handles dwg files. Anyone know of one?
