ELT Remote Gotcha
rv-9a-online(at)telus.net
PostPosted: Sun Jan 22, 2006 10:52 am    Post subject: ELT Remote Gotcha Reply with quote
In the last two weeks, every builder I talked to (including an
inspector) was not aware that most ELT remotes require a battery to operate.
No big deal, you think? Well, it is if you've mounted the ELT remote on
your panel and have no way to access the battery.
So, be forewarned... ensure you can easily remove the ELT remote to
insert/change the battery. I can access mine by removing my GPS, but a
friend of mine building a SeaStar would have had a lot of trouble if I
hadn't pointed it out.
Vern Little
Bill Denton
PostPosted: Sun Jan 22, 2006 12:02 pm    Post subject: ELT Remote Gotcha Reply with quote
JFTR...
Many Artex remote switch units DO NOT require a battery, but are instead
hardwired to ship's power.
PeterHunt1(at)aol.com
PostPosted: Mon Jan 23, 2006 3:37 pm    Post subject: ELT Remote Gotcha Reply with quote
If you have a tip-up like me, mounting the ELT remote high on the panel
gives it excellent access for replacing the battery. Now, be sure to label the
ELT remote with the date the battery must be replaced.
Pete from Clearwater
RV-6, all electric panel, full IFR, 40 hours
mlas(at)cox.net
PostPosted: Tue Jan 24, 2006 6:20 am    Post subject: ELT Remote Gotcha Reply with quote
Ameri-King requires nether.....
mark.supinski(at)gmail.co
PostPosted: Tue Jan 24, 2006 6:46 am    Post subject: ELT Remote Gotcha Reply with quote
Sorry, Mike -- but if you are referring to the Ameri-King AK-450 you are in
for a rude surprise. Here is a quote from their published feature list:
- Mini Remote Control Panel with independent Battery built-in,
therefore Interface with Aircraft Electrical Power is not required.
Having just installed a 450 last weekend, I can assure you that the AK-450
does in fact have a battery in the remote unit.
Mark Supinski
