sam.marlow
Posted: Wed Sep 20, 2006 8:17 am Post subject: Garmin Stack |
Can someone with a Garmin stack give me an idea on how much space I need to allow between units, 340, 430, sl30 ect? I'm thinging maybe the racks can go metel to metal.
Sam Marlow
RV10 Avionics
Deems Davis
Posted: Wed Sep 20, 2006 11:20 am Post subject: Garmin Stack |
Sam, I can't remember the exact dimensions, but Garmin has a requirement
for minimum spacing between radios on the stack. HOWEVER, If you use
their mounting racks (can't think of why you wouldn't want to) they have
'dimples' on the top/bottom that guarantee the mins, so that you can go
metal to metal. (I taped all of my racks together to get the final
dimensions for cutting the opening in the panel faceplate).
Deems Davis # 406
Panel/Fuse/Finishing
http://deemsrv10.com/
Sam Marlow wrote:
Quote: | Can someone with a Garmin stack give me an idea on how much space I
Sam Marlow
RV10 Avionics
Tim(at)MyRV10.com Guest
Posted: Wed Sep 20, 2006 11:43 am Post subject: Garmin Stack |
Hi Sam,
Check your install manual where they show stacking the install
tubes, but my take on it was that they stack basically on top
of eachother. They have the small rounded dents on the bottoms
of the tubes that allow for spacing.
Sam Marlow wrote:
Quote: | Can someone with a Garmin stack give me an idea on how much space I need
Sam Marlow
RV10 Avionics
brianpublic2(at)starband. Guest
Posted: Wed Sep 20, 2006 12:41 pm Post subject: Garmin Stack |
It's 0.040" and the dimples will give you that. However, keep in mind that
Garmin has not updated the UPS line to match their original products, so if
your mix includes a former UPS product such as SL30, the dimples won't line
up, and you won't have the proper clearance. Simple fix is to super-glue
a 1" square of 0.040" sheet onto the SL30 tray where the other trays contact
it.
http://brian76.mystarband.net/avionicsFeb06.htm#feb6
Another tip I learned in doing mine is that it's the outside lip of the
bottom of the tray that is supposed to be flush, so the rest of the tray is
actually a bit behind the panel.
brian
tcervin(at)valkyrie.net Guest
Posted: Wed Sep 20, 2006 3:03 pm Post subject: Garmin Stack |
Mine are metal to metal and no problems.
Tom in Ohio (RV6-A)
sam.marlow
Posted: Wed Sep 20, 2006 5:34 pm Post subject: Garmin Stack |
Great info, just what I needed!
Sam
Brian Meyette wrote:
[quote] [quote]--> AeroElectric-List message posted by: "Brian Meyette" <brianpublic2(at)starband.net> (brianpublic2(at)starband.net) It's 0.040" and the dimples will give you that. However, keep in mind that Garmin has not updated the UPS line to match their original products, so if your mix includes a former UPS product such as SL30, the dimples won't line up, and you won't have the proper clearance. Simple fix is to super-glue a 1" square of 0.040" sheet onto the SL30 tray where the other trays contact it. http://brian76.mystarband.net/avionicsFeb06.htm#feb6 Another tip I learned in doing mine is that it's the outside lip of the bottom of the tray that is supposed to be flush, so the rest of the tray is actually a bit behind the panel. http://brian76.mystarband.net/avionicsFeb06.htm brian --
Bill Schlatterer
Posted: Wed Sep 20, 2006 6:17 pm Post subject: Garmin Stack |
Sam, I didn't see it in the 430 manual but on page 5 of the SL40 Installation Manual, it specifically says "for typical installations, the SL40 requires no external cooling BUT leave a 1/8 to 1/4 inch clearance between avionics". I would assume that the SL30 puts out more heat and would be subject to the same clearances. Others mount them metal to metal and seem to have no problems. Your call
Bill S
7a Ark
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Marlow
Sent: Wednesday, September 20, 2006 11:16 AM
Subject: Garmin Stack
Sam Marlow
RV10 Avionics
FLYaDIVE(at)aol.com Guest
Posted: Wed Sep 20, 2006 9:15 pm Post subject: Garmin Stack |
In a message dated 9/20/06 12:21:14 PM Eastern Daylight Time,
sam.marlow(at)adelphia.net writes:
Sam Marlow
RV10 Avionics
Sam:
Nothing is metel to metal, as long as trays are used; you can stack as close
at the trays will allow. For cooling the 340 has a fitting for the cooling
fan hose to connect to. I suspect the other Garmin units do also.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
Posted: Thu Sep 21, 2006 4:27 am Post subject: Garmin Stack |
Sam Marlow
RV10 Avionics
Sam:
as the trays will allow. For cooling the 340 has a fitting for the cooling
Barry
"Chop'd Liver"
time."
Yamashiada
