Airflow Performance Purge Line
tgesele(at)optonline.net
PostPosted: Tue Sep 05, 2006 11:34 am    Post subject: Airflow Performance Purge Line Reply with quote
Can anyone with an airflow performance fuel injection system installed on
the -10 tell me where they penetrated the firewall for the purge line. I'm
planning on installing a 45 deg bulkhead fitting in the same location
(opposite side) as the fitting for the fuel line and want to ensure there
are no interference issues with running the purge line from there. Also, if
anyone has a picture of the setup from the engine side that they could
forward, I'd appreciate it.
Tom Gesele #473
n223rv(at)wolflakeairport
PostPosted: Tue Sep 05, 2006 4:03 pm    Post subject: Airflow Performance Purge Line Reply with quote
Just did this last week. I ran a second 45 degree fitting below the
current fuel 45 fitting on the firewall. Ran the line down the right
side of the tunnel, and put in a 90 degree bend into the left tank line.
I plan on Adel clamping the line to the right side wall of the tunnel
soon. I also had to finagle a #4 line into a #6 line with some fitting
magic, but it was no big deal (the purge line is #4).
-Mike Kraus
rv10builder(at)bellsouth.
PostPosted: Tue Sep 05, 2006 4:56 pm    Post subject: Airflow Performance Purge Line Reply with quote
Here is how I routed mine...
http://www.mykitlog.com/users/display_log.php?user=rv10builder&project=7&category=501&log=15056&row=19
Brian
40308
Tom Gesele #473
jesse(at)itecusa.org
PostPosted: Tue Sep 05, 2006 5:30 pm    Post subject: Airflow Performance Purge Line Reply with quote
Beautiful layout. With the selector on the right tank and the purged fuel
into the left line between the tank and the selector, you force the fuel
back into the tank without running a complete return line. Why did you not
just use a "T" with flared ends instead of pipe threads and pipe-to-flare
fittings?
Do not archive?
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
PostPosted: Tue Sep 05, 2006 6:13 pm    Post subject: Airflow Performance Purge Line Reply with quote
Thanks Jesse - works exactly as you described. Good point about the
fitting, just a matter of mating together two sizes of tubing. In the
end I really just copied Dan Checkoway's installation:
(http://www.rvproject.com/20030516.html). - Thanks Dan if you're listening!
fittings?
Do not archive?
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
PostPosted: Wed Sep 06, 2006 5:00 am    Post subject: Airflow Performance Purge Line Reply with quote
>Why did you not just use a "T" with flared ends instead of pipe
threads and pipe-to-flare fittings?<<
Same reason I didn't - because the return line is #4 line and the fuel
tank lines are #6.... So you have to use an AN6 tee with a pipe end,
then a reducer to a AN4 fitting. I have the exact same set up in my
-10, but I tapped into the left tank line instead of the right tank
line.
Mike Kraus
