dlm46007(at)cox.net Guest
Posted: Tue Sep 05, 2006 9:06 am Post subject: intake alternate air |
For those operating the IO540 D4A5, are you installing both hinged alternate door on the front of the box and the emergency air door on the bottom of the box?
Ray.R.Doerr(at)sprint.com Guest
Posted: Tue Sep 05, 2006 10:24 am Post subject: intake alternate air |
I just installed the one on the bottom of the Box. This is just in case the air filter is blocked by ice or anything else.
Thank You
Ray Doerr
N519RV (40250) 125 hours.
flysrv10(at)gmail.com Guest
Posted: Tue Sep 05, 2006 10:57 am Post subject: intake alternate air |
Just the emergency one for me.
Do not archive.
On Sep 5, 2006, at 1:04 PM, David McNeill wrote:
Quote: | For those operating the IO540 D4A5, are you installing both hinged alternate door on the front of the box and the emergency air door on the bottom of the box?
Tim(at)MyRV10.com Guest
Posted: Tue Sep 05, 2006 11:06 am Post subject: intake alternate air |
Ditto on that.
Doerr, Ray R [NTK] wrote:
[quote] I just installed the one on the bottom of the Box. This is
Thank You
*Ray Doerr*
*N519RV (40250) 125 hours.*
nevilleboyle(at)bencomm.c Guest
Posted: Tue Sep 05, 2006 3:15 pm Post subject: intake alternate air |
David I installed both mainly because I had the alternate air installed and the original magnetic filter bypass when the AD for the magnetic filter bypass came I ended up with both .If I was doing it again I would only fit the filter bypass.
Neville Boyle
VHNVL 14.5 hours
jesse(at)itecusa.org Guest
Posted: Tue Sep 05, 2006 5:24 pm Post subject: intake alternate air |
We’ve done both and haven’t used either in over 300 hours of flying yet, but haven’t had an emergency yet.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Tuesday, September 05, 2006 1:05 PM
Subject: intake alternate air
01234567890123
-- Date: 9/5/2006
9/5/2006
pilotdds(at)aol.com Guest
Posted: Wed Sep 06, 2006 6:28 am Post subject: intake alternate air |
Make sure you are aware of vans servce bulletin to replace the hinge on the alternate air.My engine ingested the magnet.No damage but scary.
