RV9-List Digest: 1 Msgs - 08/29/06
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
k9hxt(at)sbcglobal.net
PostPosted: Thu Aug 31, 2006 1:15 pm    Post subject: RV9-List Digest: 1 Msgs - 08/29/06 Reply with quote
I put mine and two others on top of the vertical stab. Not difficult and if you notice that is where most of the spam cans put theirs. It is out of the way and you won't trip over it or some kid won't play with is on a ramp etc. I have seem some under the tail but I don't believe that is a good place. The reception pattern is pretty uniform and clear on the top of the tail also.
Larry, RV-6A, N939LT since 2001.
"LIMA TANGO SENDS"
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
wowens(at)darientel.net
PostPosted: Sat Sep 02, 2006 1:20 am    Post subject: RV9-List Digest: 1 Msgs - 08/29/06 Reply with quote
The antenna base (hockey puck) I have is wider than the top of the rudder. Did you cut a notch and let a half inch hang out on either side?
Thanks again for your time.
Wayne
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
