SD737(at)aol.com Guest
Posted: Sat Aug 26, 2006 8:39 am Post subject: M701 AC Drive |
There is no second power source on the M701 by design. I thought initially about trying to build a boss with a seal and drive spline opposite the generator but after looking at it further, I discovered that it was never intended to drive another component. Not only is it under built, but let's assume that an A/C compressor was mounted on that section of the drive and it locked up for some reason.....The spline or shaft drive collar would fail and the fuel pump would be lost. That's why I came to the conclusion that a stand-alone system would work the best and would not compromise safety. Stacy
| - The Matronics L29-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
delfin(at)mail.pf Guest
Posted: Sat Aug 26, 2006 9:54 am Post subject: M701 AC Drive |
There is a second source of power on my M701. As far as I remember, it is about 15 cms from the high pressure pump, exactly the same that the one for the HP. I think it was originally done for an hypothetic second HP pumps (as on Vampire DH-100 for exemple)
Le 26 août 06 à 06:39, SD737(at)aol.com (SD737(at)aol.com) a écrit :
Quote: | There is no second power source on the M701 by design. I thought initially about trying to build a boss with a seal and drive spline opposite the generator but after looking at it further, I discovered that it was never intended to drive another component. Not only is it under built, but let's assume that an A/C compressor was mounted on that section of the drive and it locked up for some reason.....The spline or shaft drive collar would fail and the fuel pump would be lost. That's why I came to the conclusion that a stand-alone system would work the best and would not compromise safety. Stacy Quote: |
ntribution
