SD737(at)aol.com Guest
Posted: Sat Aug 26, 2006 8:38 am Post subject: AC Response |
Hello Ernie,
My name is Stacy Lawrence. I was asked to send you an email to let you know when my A/C application would be available for the L-29. I have already tested the unit that I built and it works perfectly. I'm currently installing it and will be using my jet to do any further R&D. I told Bob Schwarts about my approach and I'm under the impression that he and others may believe that it was as simple as taking a window unit apart and reassembling the components in the plane and converting D/C to A/C. This couldn't be farther from the truth. From reading some of your posts, I can see that you have a good understanding of some of the potential problems with this application. Some of which are liquid migration, a special expansion valve, and critical line volume and balance of the high and low sides. Everything goes out the window as soon as you start adding length or changing the ID of any lines. I have solved all of these problems over the course of months of development and bench testing. I do plan to have these units available in the late fall after I've thoroughly tested it. Take care, Stacy
| - The Matronics L29-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
