Xerion EIS (was: EFIS Comparisons)
brian
PostPosted: Wed Jan 18, 2006 5:05 pm    Post subject: Xerion EIS (was: EFIS Comparisons) Reply with quote
Mitchell Goodrich wrote:
The Auracle does come 2 different ways. A single box, which means all
the senders
are wired directly to the head unit, and a 2 box. The data aquisition
unit mounted
in the engine compartment and a supplied data cable run up to the head
unit.
Do believe that both units are/will be certified.
I vote for the 2 box. Only because of my limited wireway space, and ease
of install.
Both units have the same exact functionality.
It appears they are using a data bus. This means that they could support
multiple data collection boxes. This is a *very* good idea.
Brian Lloyd 2243 Cattle Dr.
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
Brian Lloyd
mgoodrich(at)tampabay.rr.
PostPosted: Wed Jan 18, 2006 5:37 pm    Post subject: Xerion EIS (was: EFIS Comparisons) Reply with quote
Brian,
yes they are actually using a proprietary com/data or can buss.
In the near future you will see a complete line of instrumentaion
that utilizes the can-bus.
Mitchell Goodrich
