RV10-List: Re: Full power 30° bank stall
philperry9
PostPosted: Wed Apr 24, 2024 2:51 pm    Post subject: RV10-List: Re: Full power 30° bank stall Reply with quote
It’s probably safe to say there would always be some level of control input into a constant bank turn…..due to the dihedral encouraging the plane to gently return to a wings level position.
But you are correct, they’re best viewed as a rate of change input.
On Apr 24, 2024, at 5:16 PM, Ceengland <ceengland7(at)gmail.com> wrote:
I haven't even stayed in any hotels lately, but if you're in a stabilized turn of any bank, won't the ailerons be neutral? The way I was taught, they're rate controls; if they're deflected, the bank angle is changing.
Charlie
http://forums.matronics.com/viewtopic.php?p=513511#513511
