Tight Gear Handle
JL2A
PostPosted: Wed Apr 10, 2024 8:08 pm    Post subject: Tight Gear Handle Reply with quote
Just replaced a very stiff flap handle that eventually started leaking, and now flap handle is fine but the gear handle is very hard to move!
This is only with air pressure applied. When there is no air pressure, the handles move easily.
Could there be air leaking back through the system and pushing on the wrong side of the selector disc inside the handle?
markbitterlich(at)embarqm
PostPosted: Thu Apr 11, 2024 2:29 am    Post subject: Tight Gear Handle Reply with quote
For Yak models, air from the "other side" of the gear actuator vents through the landing gear selector valve itself, so if there was air leakage through an actuator to the other side, you'd hear a hiss at your landing gear selector all the time the master air valve was turned on.
Could be the valve itself.  Ask Dennis Savarese.
Mark
From: JL2A <info(at)flyingwarbirds.com.au.matronics.org>
Date: 4/11/24 12:12 AM (GMT-05:00)
To: yak-list(at)matronics.com
Subject: Yak-List: Tight Gear Handle
--> Yak-List message posted by: "JL2A" <info(at)flyingwarbirds.com.au.matronics.org>
http://forums.matronics.com/viewtopic.php?p=513459#513459
_-============================================================
_-=          - The Yak-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-=   --> http://www.matronics.com/Navigator?Yak-List
_-=
_-=               - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-=   --> http://forums.matronics.com
_-=
_-=              - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-=   --> http://wiki.matronics.com
_-=             - List Contribution Web Site -
_-=  Thank you for your generous support!
_-=                              -Matt Dralle, List Admin.
_-=   --> https://matronics.com/contribution
draftsjust417(at)gmail.co
PostPosted: Sun Apr 21, 2024 10:28 am    Post subject: Tight Gear Handle Reply with quote
Just curious if the tight gear handle issue was resolved?Always like to hear the resolution-
Thanks-  Justin/N280NC
On Wed, Apr 10, 2024, 21:13 JL2A <info(at)flyingwarbirds.com.au.matronics.org (info(at)flyingwarbirds.com.au.matronics.org)> wrote:
--> Yak-List message posted by: "JL2A" <info(at)flyingwarbirds.com.au.matronics.org (info(at)flyingwarbirds.com.au.matronics.org)>
List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
eferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer" target="_blank">http://wiki.matronics.com
b Site -
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
jonboede(at)hotmail.com
PostPosted: Sun Apr 21, 2024 11:34 am    Post subject: Tight Gear Handle Reply with quote
Kind-of sounds like the face of the selector is going bad, maybe?
Would be curious to know, too.
On Apr 21, 2024, at 1:32 PM, Justin Drafts <draftsjust417(at)gmail.com> wrote:
 Just curious if the tight gear handle issue was resolved? Always like to hear the resolution-
FORUMS -
WIKI -
b Site -
