Yak-List Digest: 1 Msgs - 02/02/24
yakman285(at)gmail.com
PostPosted: Sat Feb 03, 2024 3:37 am    Post subject: Yak-List Digest: 1 Msgs - 02/02/24 Reply with quote
Reading through my old document from 2014 and CJ Maint. Vol I, Appendix VII, the CD-5 mag setting resulted in total advance applicable to the octane rating of the fuel the Chinese had at the time.
The M-14P total advance is a lower value, using the fixed magneto that limits advance to 22-24 degrees by piston. ADJUSTING the setting of the CD-5 to achieve the 24 degrees resulted in about a two degree retarded value from what the Chinese used on a slower turning engine, using lower octane.
These are conservative numbers, given the wide range of altitudes and air density encountered during flight. Using manual leaning, the Huosai engine can be adjusted to conditions by the pilot. On the M-14P, the carb settings do the adjustments... how accurately was the carb was set?? Leaning for max efficiency on flat engines differs from radials because radials distribute the mixture more evenly to each cylinder. Pays your money, takes your chances.
Craig Payne
Virus-free.www.avg.com[url=#m_-6217763269057398783_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
On Sat, Feb 3, 2024 at 2:33 AM Yak-List Digest Server <yak-list(at)matronics.com (yak-list(at)matronics.com)> wrote:
Today's complete Yak-List Digest can also be found in either of the
two Web Links listed below.  The .html file includes the Digest formatted
and Message Navigation.  The .txt file includes the plain ASCII version
of the Yak-List Digest and can be viewed with a generic text editor
HTML Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2024-02-02&Archive=Yak
Text Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2024-02-02&Archive=Yak
                           Yak-List Digest Archive
                     Total Messages Posted Fri 02/02/24: 1
Today's Message Index:
     1. 09:52 AM - Mag Timing CD5  (glipaz)
________________________________  Message 1  _____________________________________
Time: 09:52:47 AM PST US
Subject: Mag Timing CD5
From: "glipaz" <glipaz(at)yahoo.com (glipaz(at)yahoo.com)>
Brain trust:
I know that on an M-14p with a Russian M9F magneto, timing on the prop is set at
14-16* BTDC.  This translates to around 22-24* BTDC on the crank.
Assuming an M-14p motor with CD-5 (Chinese)magnetos stamped 25*, what is the proper
angle on the prop BTDC?
According to Craig Paynes chart for this configuration it suggests 8.8* BTDC on
the crank and 5.8* BTDC on the prop.  I dont understand this figure.
Gil
http://forums.matronics.com/viewtopic.php?p=513186#513186
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
="noreferrer" target="_blank">https://matronics.com/contribution
