Shared ground plane
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
prhutson
PostPosted: Fri Mar 17, 2023 9:59 am    Post subject: Shared ground plane Reply with quote
I need to install a ground plane in my composite fuselage (Glastar). Is it acceptable to have both the transponder and COM antenna attached to the same ground plane? If so, how much separation is needed, and is it better to be tandem or side by side?
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
Paul Hutson
Middleton, WI
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
