Whelen Flashing on One side Ceases after a Minute or so
matronics(at)rtist.nl
PostPosted: Tue Dec 21, 2021 12:20 pm    Post subject: Whelen Flashing on One side Ceases after a Minute or so Reply with quote
Hello George,
If you have the Whelen central power box, you can swap left and right
strobe connectors and see if the problem moves with the connection. If
it does, then the problem is in the power box. If it still fails on the
same side then it's with the wiring/bulb on that side.
Cheers,
Rob
Hoevelaken Wink
On 12/21/2021 9:17 AM, George Nielsen wrote:
<genie(at)swissmail.org>
Initially my Whelen flasher works on both the starboard and port wing.
After about a minute of flashing it ceases to work on the starboard
wing but continues on the port wing. This has been repeated with the
same result every time so I doubt whether the bulb or wiring are at
fault. What could be the problem and how can I make both sides flash
continuously? Thanks.
George Nielsen
Avid Flyer I-6640
The Hague, the Netherlands
