Brake Caliper Position
Area-51
PostPosted: Sat Nov 27, 2021 6:38 pm    Post subject: Brake Caliper Position Reply with quote
Pre-empting Bud will probably know the answer... Does anyone know if repositioning the brake caliper 180 degree to the upper position on a mono interfere with the rudder cables when the main gear is in retracted position? Thanks...
peterz(at)zutrasoft.com
PostPosted: Sat Nov 27, 2021 7:08 pm    Post subject: Brake Caliper Position Reply with quote
Only 90 (in line with the swingarm) is all you'll get with major tunnel surgery.
And yip.
PeteZ
On Nov 27, 2021, at 9:45 PM, Area-51 <goldsteinindustrial(at)gmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=504964#504964
budyerly@msn.com
PostPosted: Sun Nov 28, 2021 7:52 am    Post subject: Brake Caliper Position Reply with quote
Yep is right. Cable/module interference will happen.
Pain in the butt. Some of the aircraft had a partially hanging brake caliper. (Don't know if it was miss-drilled or what. Only way to clean it up was a small fairing attached to the arm and fuselage to clean it up.
I never liked the fairing from a maintenance and time to fabricate standpoint. Kim Prout did one of the first ones.
Bud Yerly
