SD8 - rewinding for 28V
digidocs
PostPosted: Wed Aug 25, 2021 8:13 pm    Post subject: SD8 - rewinding for 28V Reply with quote
I have a SD8 alternator (14V) on the shelf and a 28V single alternator system in the hangar.
Under the guise of education and recreation, I wonder if I could disassemble the SD8 and rewind it with more turns of smaller wire to make it more appropriate for a 28V application?
Conceptually this is a simple idea, but I wonder if in practice I will have issues like losing strength in the magnets when I disassemble the alternator, or it being impossible to remove the existing windings without damage to the stator, etc.
Any and all input welcome.
PostPosted: Thu Aug 26, 2021 8:35 am    Post subject: SD8 - rewinding for 28V Reply with quote
At 11:13 PM 8/25/2021, you wrote:
--> AeroElectric-List message posted by: "digidocs" <junk(at)dcarr.org>
Under the guide of education and recreation, I wonder if I could disassemble the SD8 and rewind it with more turns of smaller wire to make it more appropriate for a 28V application?
It is possible/practical to rewind the SD8 stator
for other performance goals. There are no risks to
the hardware for having disassembled it.
You basically need to double the number of turns
per pole and use smaller wire so that the increased
turns do not overrun the available space.
Count the turns on each pole as it's disassembled
and note the wire routing between poles for
installing the new winding.
Remember that cross section of the wire varies
as square of diameter. So for 1/2 the area, you'll
need wire on the order of 0.7x the diameter of
the original.
Good luck! Let us know what you discover.
out of that stuff?"
