Is there a switch configuration that will do this?
david(at)carter.net
PostPosted: Fri Jun 18, 2021 10:54 am    Post subject: Is there a switch configuration that will do this? Reply with quote
>  You need a DP3T ON-ON-ON switch.
Joe - thank you, it appears that would work electrically. It took me a few minutes to decipher the actions of this switch, but I got there.
However, I have not yet found one in a form factor that would match the rest of the standard toggles in my panel. I may have to just live with two switches. It's not the end of the world, but it's not as elegant.
Thanks!
David Carter
david(at)carter.net (david(at)carter.net)
david(at)carter.net
PostPosted: Fri Jun 18, 2021 1:10 pm    Post subject: Is there a switch configuration that will do this? Reply with quote
>    What switches are you using?
It appears that Stein's crew is putting these in by default unless I ask for something else.
https://www.steinair.com/product/toggle-switch-spst-onoff-fast-on-terminals/
David Carter
