Z-14 question
Voyager
PostPosted: Sat May 29, 2021 2:07 pm    Post subject: Z-14 question Reply with quote
Bob, a question about Z-14. I am considering this architecture for my S-21.
The starter/cross-feed switch is listed as S700-2-7, but the figure looks more like a 2-5 and the function seems to make that switch the correct choice. I can’t see a reason why the non-starter cross-feed position would also be momentary. Is this just a typo on the switch designation?
Matt Whiting
PostPosted: Sat May 29, 2021 7:10 pm    Post subject: Z-14 question Reply with quote
At 05:06 PM 5/29/2021, you wrote:
--> AeroElectric-List message posted by: "Matthew S. Whiting" <m.whiting(at)frontier.com>
Yes, be sure you're getting the latest revision
level of any Z-figure from the website. The
current revision for Z-14 dated 2013 is "P"
where the switch callout as indeed corrected to
S702-2-5.
out of that stuff?"
Voyager
PostPosted: Sun May 30, 2021 4:32 am    Post subject: Z-14 question Reply with quote
Hmmmm. I got it from the web site so I thought it was the latest. I got it here: http://www.aeroelectric.com/Books/Connection/AppZ_12A3.pdf
I just checked and this version is still incorrect. I am assuming there must be another location or maybe you only update the CAD files and I don’t have a CAD program to read those so I usually look at the PDFs. I will find a .DWG viewer and check the CAD version.
Matt
On May 29, 2021, at 11:13 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
S702-2-5.
out of that stuff?"
david(at)carter.net
PostPosted: Sun May 30, 2021 4:55 am    Post subject: Z-14 question Reply with quote
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/
On Sun, May 30, 2021 at 6:33 AM Matthew S. Whiting <m.whiting(at)frontier.com (m.whiting(at)frontier.com)> wrote:
Matt
On May 29, 2021, at 11:13 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: "Matthew S. Whiting" <m.whiting(at)frontier.com (m.whiting(at)frontier.com)>
  S702-2-5.
  out of that stuff?"
David Carter
david(at)carter.net (david(at)carter.net)
johnbright
PostPosted: Sun May 30, 2021 5:03 am    Post subject: Re: Z-14 question Reply with quote
Voyager wrote:
Hmmmm. I got it from the web site so I thought it was the latest...
I made a cheat sheet.
https://docs.google.com/document/d/1iR03DwNeHZy8hO7xBtALPb4_Tl0EY3OdZnAEIxpfMVY/edit?usp=sharing
John Bright, RV-6A, at FWF, O-360
Z-101 single batt dual alt SDS EM-5-F.
john_s_bright@yahoo.com, Newport News, Va
N1921R links
Voyager
PostPosted: Sun May 30, 2021 5:25 am    Post subject: Z-14 question Reply with quote
Thanks. I’d been in this directory once before, but somehow found my way to the older one this last time.
Matt
S702-2-5.
out of that stuff?"
David Carter
PostPosted: Sun May 30, 2021 8:47 pm    Post subject: Z-14 question Reply with quote
This link is Rev 12 BOOK, not the page-per-system archives . . .
out of that stuff?"
PostPosted: Sun May 30, 2021 8:48 pm    Post subject: Z-14 question Reply with quote
These are the PPS archives where BOTH autocad
dwg and Acrobat pdf files are updated and
stored.
out of that stuff?"
Voyager
PostPosted: Mon May 31, 2021 9:36 am    Post subject: Z-14 question Reply with quote
Thanks, Bob!
Matt
On May 31, 2021, at 12:50 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
stored.
out of that stuff?"
