locking nuts and oil fittings
jonboede(at)hotmail.com
PostPosted: Sat May 15, 2021 4:53 pm    Post subject: locking nuts and oil fittings Reply with quote
Y'all,
I've seen two oil outlet fittings slowly work themselves loose now because the lock washer or star washer didn't quite do its job.
I'm not a fan of nylock nuts on aircraft, so I'm looking for other options.
Anybody have an opinion on "JAP Nuts" aka "Jet Nuts" for use in this situation? I've found M5 jet nuts that meet the MS21042 MIL-SPEC and I'm thinking of using those.
Jon
dsavarese0812(at)bellsout
PostPosted: Sun May 16, 2021 4:51 am    Post subject: locking nuts and oil fittings Reply with quote
Jon,
Those will work.  Metric, steel/cad plated (f you can find cad plated
metric nuts) lock nuts will also work great.  Instead of ny-lock nuts,
you could also use (if you can find them in metric sizes) fiber lock
nuts which are widely used on standard category and experimental (read
kit aircraft) aircraft.
A. Dennis Savarese
334-546-8182
www.yak-52.com
On 5/15/2021 8:52 PM, Jon Boede wrote:
Y'all,
options.
Jon
