boyerjrb(at)comcast.net Guest
Posted: Fri Mar 26, 2021 6:42 am Post subject: Ragwing Ultra-Piet |
Paint looks good, just needs more. I like the yellow. Cheers, Jim
Quote: | On 03/25/2021 6:18 PM cdlwingnut <lee_chad(at)hotmail.com> wrote:
getting too low on the echo bond glue to start the top fabric of the right wing. So while waiting for an order of it I made a trip to sherwin williams for some paint. After testing it on some scrap fabric I felt brave enough to brush a coat on the vertical fin. I plan to brush the first coat on to get it into the fabric then spray the second and if needed the third coat on.
http://forums.matronics.com/viewtopic.php?p=501101#501101
http://forums.matronics.com//files/20210325_150316_resized_636.jpg
| - The Matronics Pietenpol-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pietenpol-List |
cdlwingnut
Posted: Fri Mar 26, 2021 3:08 pm Post subject: Re: Ragwing Ultra-Piet |
did some wet sanding today then got the elevators primed.
Description: |
Filesize: |
223.63 KB |
Viewed: |
257 Time(s) |
cdlwingnut
Posted: Tue Mar 30, 2021 4:41 pm Post subject: Re: Ragwing Ultra-Piet |
I did a little bit more wet sanding on the elevators one has two coats of primer now and is ready for some color the other only has one coat on it.
The echobond came in as well so I worked late and got the fabric glued onto the top of the right wing. A few passes of the iron and it will be ready for rib stitching and tapes.
Description: |
Filesize: |
229.38 KB |
Viewed: |
240 Time(s) |
cdlwingnut
Posted: Wed Mar 31, 2021 3:27 pm Post subject: Re: Ragwing Ultra-Piet |
And the fabric is shrunk
Description: |
Filesize: |
197.94 KB |
Viewed: |
228 Time(s) |
cdlwingnut
Posted: Fri Apr 02, 2021 1:41 pm Post subject: Re: Ragwing Ultra-Piet |
more rib stitching. one rib with the long strait needle one rib with the curved needle. the ribs with the compression braces have to have the curved needle used since they block the path of the long one.
Description: |
Filesize: |
130.92 KB |
Viewed: |
211 Time(s) |
cdlwingnut
Posted: Mon Apr 12, 2021 5:26 pm Post subject: Re: Ragwing Ultra-Piet |
still working on the rib stitching got all the ribs I can use the long needle on done and all the top of the ribs i have to use the curved needle on
Description: |
Filesize: |
151.29 KB |
Viewed: |
104 Time(s) |
Posted: Tue Apr 13, 2021 8:23 am Post subject: Ragwing Ultra-Piet |
Looking good; makes you think you will have an airplane soon.
cdlwingnut
Posted: Fri Apr 16, 2021 3:42 pm Post subject: Re: Ragwing Ultra-Piet |
flipped the wing over an rib stitched the ribs with the braces blocking the path of the long needle. now the wing is ready for tapes.
Description: |
Filesize: |
150.99 KB |
Viewed: |
58 Time(s) |
