Richard Pike
Joined: 09 Jan 2006 Posts: 1669 Location: Blountville, Tennessee
Posted: Fri Mar 12, 2021 1:48 pm Post subject: Prop pitch? |
Got the three blade 72" Warp Drive prop mounted today, any suggestions for initial pitch angle?
Stock Rotax 582, 3.47:1 E box.
The fewer times I need to loosen and readjust everything, the happier I'll be.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
gdhelton(at)gmail.com Guest
Posted: Fri Mar 12, 2021 3:07 pm Post subject: Prop pitch? |
Hi Pete, somewhere between 6and 8 degrees should work. Do you have a digital protractor? George
Quote: | On Mar 12, 2021, at 4:51 PM, Richard Pike <thegreybaron(at)charter.net> wrote:
Richard Pike
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=500946#500946
Richard Pike
Posted: Sat Mar 13, 2021 7:14 am Post subject: Re: Prop pitch? |
Yes, I do. If the rain holds off, might get to run it this afternoon.
Kingsport, TN 3TN0
Posted: Sat Mar 13, 2021 2:55 pm Post subject: Prop pitch? |
Great, Richard. Let me know how it turns out.
Quote: | On Mar 13, 2021, at 10:16 AM, Richard Pike <thegreybaron(at)charter.net> wrote:
Richard Pike
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=500960#500960
Richard Pike
Posted: Sat Mar 13, 2021 5:34 pm Post subject: Re: Prop pitch? |
Well - tach didn't work right, and oil pump didn't work right. I only put in 1 gallon of gas with premix, glad I did. With the wings off, I could reach my hand in and push the oil pump lever to max - still minimal smoke when it should have been fogging the mosquitos. Shut it off.
OTOH, it ran as smooth as anything I have ever seen, I am thinking that once I get it sorted out I will like it.
Maybe next week.
Kingsport, TN 3TN0
Posted: Sun Mar 14, 2021 4:27 am Post subject: Prop pitch? |
This is kind of dumb question but , did you bleed your oil pump?
Quote: | On Mar 13, 2021, at 8:36 PM, Richard Pike <thegreybaron(at)charter.net> wrote:
Maybe next week.
Richard Pike
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=500965#500965
Richard Pike
Posted: Sun Mar 14, 2021 5:13 am Post subject: Re: Prop pitch? |
As in take the 10mm bolt on the pump loose and let the oil from the oil tank run out through it? Yep.
PS: when something is not working for no obvious reason, there are no dumb questions. At least not in my case.
Kingsport, TN 3TN0
Richard Pike
Posted: Sat Mar 20, 2021 4:37 pm Post subject: Re: Prop pitch? |
Finally got everything together and flew this afternoon. WOW! The 72" prop and 3.47:1 ratio really accelerates!
Still got some things to sort out, with 13 degrees of pitch, static tied down was 6250, climbing out the prop loaded up a bit and was only turning 6000-6100. Egt's were good, pulled back to 54-5500 rpm cruise, egt's were good.
Repitched the prop to 12 degrees, climbout was 63-6400 rpm, climbing 1,000/min, but as soon as I reduced throttle to 5500, the EGT's went up to 1200 degrees. Eased the throttle back to around 5,000, went back and landed.
My initial reaction is that the prop unloaded a bit much in cruise, which jacked the egt's, but first I'll go through the carbs and make sure that everything is like it's supposed to be.
The wife says that it is remarkably quiet, and that is w/o the after muffler installed.
Kingsport, TN 3TN0
lcottrell
Joined: 29 May 2006 Posts: 1490 Location: Jordan Valley, Or
Posted: Sat Mar 20, 2021 5:03 pm Post subject: Prop pitch? |
Sounds as though you need to raise the needles, too lean.
On Sat, Mar 20, 2021 at 6:39 PM Richard Pike <thegreybaron(at)charter.net (thegreybaron(at)charter.net)> wrote:
Quote: | --> Kolb-List message posted by: "Richard Pike" <thegreybaron(at)charter.net (thegreybaron(at)charter.net)>
Richard Pike
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=501045#501045
The older I get, the less tolerant I am of those who are intolerant of others.
Posted: Sun Mar 21, 2021 3:25 am Post subject: Prop pitch? |
Hi Richard, it sounds like your pretty close to me. I would expect that increase in EGT at throttle back between 4800 and 5000 rpm.( to be avoided.) Some Rotax engines have that lean spot at reducing power after having been run at high power settings. Your static pull sounds pretty close as does you climb out rpm sounds good. I would suggest raising your carb needles maybe one
notch and installing your muffler for a little back pressure. Actually I’d just install the muffler and try it again. I’m not much on multiple adjustments at one time. George
Quote: | On Mar 20, 2021, at 8:39 PM, Richard Pike <thegreybaron(at)charter.net> wrote:
Richard Pike
Kingsport, TN 3TN0
