Alternator Ground
David Lamphere
PostPosted: Thu Jan 14, 2021 2:07 am    Post subject: Alternator Ground Reply with quote
That’s one I actually think I can answer!
The ground is through the alternator’s chassis, mount, engine case and ground strap from engine to firewall ground terminal.
That’s why having a good ground connection to the engine is important.
Dave
On Jan 13, 2021, at 10:26 PM, Dan <limadelta(at)gmail.com> wrote:
I have a Continental IO 550 with a Kelly 70 amp 12 volt alternator. The wiring diagram shows two field terminal posts (F1 and F2), a positive terminal, and an "AUX" terminal. It does not show a ground. Any idea how this alternator is supposed to be wired to ground? See attached pic.
Dan
<Alternator pic.pdf>
alec(at)alecmyers.com
PostPosted: Thu Jan 14, 2021 4:38 am    Post subject: Alternator Ground Reply with quote
Ground is through the metal frame of the alternator, bolted to the engine, no?
Dan
PostPosted: Thu Jan 14, 2021 8:16 am    Post subject: Alternator Ground Reply with quote
At 04:03 AM 1/14/2021, you wrote:
--> AeroElectric-List message posted by: David and Elaine Lamphere <dalamphere(at)comcast.net>
Dave
Correct. Both starter and alternator seek
ground through their attachments to the
engine. That fat/flexible jumper from
crankcase to firewall ground stud is
really important.
Further, this alternator has a 2-terminal
field connection. One of those terminals
should be grounded to alternator case.
out of that stuff?"
jluckey(at)pacbell.net
PostPosted: Thu Jan 14, 2021 9:34 am    Post subject: Alternator Ground Reply with quote
Hey Bob,
I have 2 questions:
1. Is the reason that some alternators surface both ends of the field so that the end user can select either an A-Circuit or B-Circuit regulator? (Thus giving the user more regulator choices.)
If so, then your advice:
"Further, this alternator has a 2-terminal field connection. One of those terminals should be grounded to alternator case. "
would only apply to an B-Circuit regulator.
2. Is that correct?
I seem to remember working on some big Leece Neville alternators (read big & expensive) where both sides of the field were available but don't remember what regulators were used (that was decades ago).
3. Are you aware of any automotive vehicles where they used and alternator with both side of the field exposed? ( I imagine not since in the automotive world it's all about cost)
-Jeff
On Thursday, January 14, 2021, 08:25:35 AM PST, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
Dave
really important.
out of that stuff?"
rparigoris
PostPosted: Thu Jan 14, 2021 1:22 pm    Post subject: Re: Alternator Ground Reply with quote
Hi Group I helped a friend a number of years ago chase down cause of a flaky alternator output on his V-Tail Bonanza. He recently had a Major. A&P changed regulator. Owner took alternator to a car parts place and had alternator tested and all was well? When I looked at alternator it looked beautiful, it was newly painted. I tried to tighten the two halves of the alternator together and things were not tremendously tight. This was after a flight when things were hot. I was able to put my thumbnail into the new paint and it was thicker than I think it should have been. I loosened halves, pulled apart enough to clean of paint between halves and re tightened. Problem was paint was insulating connection of 2 halves of alternator. Ron P.
bob.verwey(at)gmail.com
PostPosted: Thu Jan 14, 2021 9:49 pm    Post subject: Alternator Ground Reply with quote
Very interesting !
On Thu, 14 Jan 2021, 23:30 rparigoris, <rparigor(at)hotmail.com (rparigor(at)hotmail.com)> wrote:
--> AeroElectric-List message posted by: "rparigoris" <rparigor(at)hotmail.com (rparigor(at)hotmail.com)>
http://forums.matronics.com/viewtopic.php?p=500232#500232
AdventureD
PostPosted: Fri Jan 15, 2021 8:38 am    Post subject: Re: Alternator Ground Reply with quote
[/quote]
really important.
Bob . . .[/quote]
Interesting. I had simultaneously contacted Continental (It's an IO550), and they said to run a ground wire from a screw holding the (??alternator brush"") to the case. But if the alternator is already grounded via attachment to the case, why would that be needed? They did not mention grounding the second field terminal to the case. So now I'm confused Sad
Separately, the SD20 backup alternator field also has two leads and it takes a connector that I either lost or was not supplied with the alternator. (See attached pic). Anyone know where I can get that two lead connector? Maybe an auto parts shop? And does one of those wires ground to the alternator case?
 Filesize:  93.23 KB
 Viewed:  11030 Time(s)
rparigoris
PostPosted: Sat Jan 16, 2021 10:59 am    Post subject: Re: Alternator Ground Reply with quote
Hi AdventureD "if the alternator is already grounded via attachment to the case, why would that be needed?" See my post on this thread about the V tail Bonanza alternator. I located a bad connection between the two halves of the alternator. Running a separate wire to ensure the back half of the alternator isn't a bad idea if you didn't want to disassemble alternator. Ron P.
rparigoris
PostPosted: Sat Jan 16, 2021 7:29 pm    Post subject: Re: Alternator Ground Reply with quote
Hi AdventureD For SD20 connector: https://bandc.com/product/replacement-field-connector-for-alternators-l-40-bc410-h-bc425-1-sk35-lom30/ as far as field wires, they are to be paralleled to regulator. I have a SD20S and just twisted 2 wires together from regulator to go to both field wires. One is not a ground. You can just make a short paralleled wire as well. Here's install manual: https://bandc.com/wp-content/uploads/2018/05/install-instructions-bc410_revC.pdf As far as grounding for SD20, it's grounded by the 4 mounting nuts. I'm going the belt and suspenders route and running an extra ground from one of the screws on the brush side of case to engine ground. Note they want you to cross tighten to 20 inch lbs, then go to 60 to 70 inch lbs. I'm going to weld up a 12 point torque adapter for my 1/4" torque wrench. Manual tells you torque value for B+ nut. Best not tighten to the old stand by of stripping and backing off 1/2 turn! Ron P.
PostPosted: Sun Jan 17, 2021 10:14 am    Post subject: Alternator Ground Reply with quote
At 09:29 PM 1/16/2021, you wrote:
--> AeroElectric-List message posted by: "rparigoris" <rparigor(at)hotmail.com>
There is only ONE wire from the field
connector to the regulator on B&C wound-
field alternators.
These are automotive conversions where
two of the original terminals on the back
were control and warning light connections.
The conversion process removes the stock
regulator and they used to tie ALL pins
of the rear end bell connector together
such that any one would suffice as a field
connection. The are always configured to
operate as B-circuit fields (one brush
grounded inside).
wire as well.
Twisted wires? You lost me there.
Okay, yeah. Instructions call for tying
both pins in the connector together with
a jumper at the plug . . . this is for
redundancy in the fast-on terminals. One
wire from alternator field to regulator
suffices.
I note that they recommend crimp+solder
for applying those open barrel fast-on
terminals. Nothing 'wrong' with that but
if you lack confidence in the crimp
quality of your crimp tools, review
this document
https://tinyurl.com/y6g6rl9f
on page 11 we find a table of minimum
tensile strength of various crimped
terminals. In the 'Connection' I
describe a po' boy's technique for
validating crimp quality.
Suggest you validate your wire/terminal/tool
configurations before incorporating them
into your airplane. The back of the SD20
is not the ONLY place where crimp quality
is of importance . . . soldering of qualified
crimps is unnecessary.
For what purpose? The resistance between
components of the assembled case is measured
in micro-ohms . . . a milli-ohm jumper around
these joints is of no electrical value.
Hedge against what other condition . . . mechanical
looseness that disconnects the end bell from the
rest of the alternator? Those fasteners are
like prop bolts and strut attachments. I.e.
at the very bottom of risk levels in a reliability
study.
Manual tells you torque value for B+ nut. Best not ighten to
Never heard of such a practice. The physics of
achieving the required make up forces by measuring
the tightening force on a threaded fastener
is quite clear. Backing off any fastener after
achieving the specified tightening torque has
no obvious merit.
out of that stuff?"
 Filesize:  36.42 KB
 Viewed:  10967 Time(s)
PostPosted: Sun Jan 17, 2021 12:12 pm    Post subject: Re: Alternator Ground Reply with quote
Bob, I think he was joking with that sentence.
Joe Gores
PostPosted: Sun Jan 17, 2021 12:35 pm    Post subject: Alternator Ground Reply with quote
Opps! Missed 'stripping' . . . my 9th grade
English teacher would keep me after school
for that one!
out of that stuff?"
rparigoris
PostPosted: Sun Jan 17, 2021 1:27 pm    Post subject: Re: Alternator Ground Reply with quote
Hi Bob As far as twisting 2 wires together, it was just to keep them together and make them a bit stronger. I decided to use 2 wires instead of one for the field because I need to span a distance from the regulator which is in the starboard footwell to the engine and 2 wires are a bit more robust. Using 1 wire with a parallel splice is fine electrically.
As far as grounding the SD20S goes, there's a gasket installed on the vacuum pad that insulates the large surface area. That said you do have 4 lock washers and nuts attached to studs in the engine case. If you read earlier in this thread about my finding a V-Tail Bonanza alternator with poor contact between the two halves of the alternator causing problems. True it was paint at fault, but between the gasket decreasing surface area, and the fact that B&C makes a new nose for the SD20S that I'm just not certain that it has a great contact with the back half. If looks like it might be plated? Not sure if plating is conductive? Also on Rotax they tend to use Loctite on many things and I have heard that when Loctite gets old, it can cause high resistance in senders. Can that happen on studs too? Perhaps not, but I can't speak with certainty. I'm pretty certain B&C has their act together and would have addressed connection if there was a problem with ground between the case halves. A lot easier to run a 5" piece of wire to a pretty nice grounding pad nearby. Ron P.
