Battery Charger
phudes(at)ix.netcom.com
PostPosted: Sat Jan 09, 2021 11:40 pm    Post subject: Battery Charger Reply with quote
Old battery charger stopped working. What is the current recommendation for a charger and battery minder?
Pete Hudes
dj_theis
PostPosted: Sun Jan 10, 2021 4:00 am    Post subject: Re: Battery Charger Reply with quote
I’ve had good luck with Schumacher . A little more expensive than what can be bought at HF but I’ve had good performance for planes boats and autos.
https://www.amazon.com/Battery-Chargers-Schumacher/s?keywords=Battery+Chargers&rh=n%3A15707061%2Cp_89%3ASchumacher&c=ts&ts_id=15707061
The brand, “battery tender” comes to mind and I might actually have a small one of those around that seems to behave well. I look for a switch on the charger to allow for selection-between AGM and “wet lead acid.”
I think Bob ran some tests on lessor brands with good results And he has a great explanation in his book on chargers that he’s expanded on in this forum, if you do a search.
Dan Theis.
Dan Theis
Scratch building Sonex #1362
Still working on the Revmaster Alternator improvement
PostPosted: Sun Jan 10, 2021 5:43 am    Post subject: Battery Charger Reply with quote
At 01:37 AM 1/10/2021, you wrote:
--> AeroElectric-List message posted by: <phudes(at)ix.netcom.com>
How big a charger? My local Walmart stocks a range
of Schumacher chargers as well as the now legendary
Battery Tender Jr.
out of that stuff?"
PostPosted: Sun Jan 10, 2021 12:46 pm    Post subject: Battery Charger Reply with quote
PostPosted: Sun Jan 10, 2021 1:29 pm    Post subject: Battery Charger Reply with quote
Battery is a PC 680 in a RV9A.
Sounds like all your needing is a Battery Tender
for battery maintenance. It will recharge your
PC680, albeit slowly. But how often do you need
to recharge badly depleted battery?
out of that stuff?"
