Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 25204 Location: Livermore CA USA
Posted: Tue Jan 05, 2021 4:49 pm Post subject: Need Built and Tested Left PP QB Fuel Tank for RV-8... |
Dear Listers,
After my landing mishap in 2011, the replacement left fuel tank I had
built for my PP QB RV-8 has big leaks in at least four places. Slosh
would probably fix it, but everybody including Van's says "don't slosh!".
Does anyone have a lead on a Pre-Punched, preferably Quick Build LEFT
Fuel Tank for an RV-8 that is in 10/10 condition? Maybe from an RV-8
that had only right wing damage. I would like a tank that is proven
to not leak with no damage, and with a fixed fuel pickup.
I would love to get my RV-8 back in the air. The prospect of
building a new fuel tank from parts seems daunting and time consuming
right now, and prone to dealing with leaks again.
Thank you,
RV-8 N998RV
http://www.mattsrv8.com
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ Matt Dralle
garyvanremortel(at)gmail. Guest
Posted: Tue Jan 05, 2021 5:18 pm Post subject: Need Built and Tested Left PP QB Fuel Tank for RV-8... |
Matt-
There are five RV Tank builders listed in the Yeller Pages if you are so inclined.
-GV
On Tue, Jan 5, 2021 at 4:54 PM Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)> wrote:
Quote: | --> RV-List message posted by: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
Dear Listers,
Thank you,
RV-8 N998RV
ist" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV-List
FORUMS -
WIKI -
b Site -
     -Matt Dralle, List Admin.
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Tue Jan 05, 2021 6:29 pm Post subject: Need Built and Tested Left PP QB Fuel Tank for RV-8... |
Less daunting might be to cut access holes in the back plate and seal the leaks with Proseal. Van's makes a kit with the access panel, doubler and hardware. Even one it each bay is way better than building new tanks.
Greg Young
swayze(at)europa.com Guest
Posted: Thu Jan 07, 2021 12:48 am Post subject: Need Built and Tested Left PP QB Fuel Tank for RV-8... |
Hey Matt,
Just a word of encouragement, building a new tank isn't that big of a
deal. You did such a good job building your plane, I have no doubt you
could do this easily and do a good job. The parts are all pre-punched and
it goes together fast and foolproof. Just a bunch of ribs, skin, and
Proseal. You can check out my website and see how I built two of them, and
not a leak anywhere. People make too much of this. Don't overthink it. I
have a friend in the Seattle area, Stephen Christopher, who had a bird
strike that put a big dent in one of his fuel tanks, and he built one in
short order to replace it. And he even had to paint it. You don't even
have to do that! He was back flying in about 2 weeks. Anyway, I hope this
helps!
Bruce Swayze
www.BrucesRV7A.com
Quote: |
Dear Listers,
Thank you,
RV-8 N998RV
hcrv6(at)comcast.net Guest
Posted: Thu Jan 07, 2021 11:19 am Post subject: Need Built and Tested Left PP QB Fuel Tank for RV-8... |
Hey Matt, Danny Parker did what Greg is suggesting on both tanks on his RV-6. In Danny's case he did it to remove sloshing compound that was coming loose and blocking his fuel pickups but he could give you some tips. I think it would beat building a new tank. Danny has moved but his airplane is still here and he comes around pretty often.
<pre>Harry Crosby</pre>
[quote] On 01/05/2021 6:29 PM bigdog(at)bentwing.com <bigdog(at)bentwing.com> wrote:
Greg Young
Airmarty2
Posted: Thu Jan 07, 2021 11:32 am Post subject: Need Built and Tested Left PP QB Fuel Tank for RV-8... |
FWIW, Some people even use the Vans Hub Cap as a patch to the hole you cut in the back of the gas tank. Even gets you a few additional ounces of fuel.
For mine, I ended up drilled out and sacrificed the back support aluminum panel and re-applying pro-seal to the entire fuel tank. In this manner, it didn’t need to be repainted and only cost me that one part.
Marty Heller
RV-7, N724HR ~450 hours KSUT
Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows 10
Sent: Thursday, January 7, 2021 2:25 PM
To: rv-list(at)matronics.com<mailto:rv-list(at)matronics.com>; bigdog(at)bentwing.com<mailto:bigdog(at)bentwing.com>
Subject: RE: Need Built and Tested Left PP QB Fuel Tank for RV-8..
_________________ Marty
RV-7 (Flying)
Southport, NC (KSUT) |
Ceengland
Posted: Thu Jan 07, 2021 11:44 am Post subject: Need Built and Tested Left PP QB Fuel Tank for RV-8... |
To expand on that a bit, there's slosh, and then there's flow-able sealant.
Flamemaster CS3600 is a one-part sealant that can be used alone, or as a
topcoat over beads of regular polysulfide sealant. I've used it to
repair leaks in polysulfide-sealed tanks. The old 'slosh' coated the
entire interior of the tank, including the broad expanses of sheet metal
that almost certainly didn't get the attention and cleaning that the
faying surfaces did, meaning that adherence was often poor, and large
sheets came off to wrap around fuel pickups. When I used the 3600, I
'targeted' the areas of the leaks, and tried to restrict its coating to
just the areas that needed sealing.
I (and a *lot* of other RV owners) have seen polysulfide go soft and
seemingly revert to uncured state, but I haven't seen that problem with
the CS3600.
Matt, I'd be happy to talk to you by phone (easier than endless typing)
if you're interested in tackling the repairs yourself. email me off-list
for my phone number if you want to talk.
Charlie
> Greg Young
_________________ Charlie |
