D-Sub High Density 78 female - solfder or crimp contacts
PostPosted: Mon Jan 04, 2021 2:52 pm    Post subject: D-Sub High Density 78 female - solfder or crimp contacts Reply with quote
At 03:37 PM 1/4/2021, you wrote:
Hi Group.
What type contacts would you recommend for a 78 female connector - solder or crimp, and why?
It seems that solder type are easier to find and less expensive.
The connector will be used for a relays box to select VHF nav signals to an HSI.
Rumen....
Do you already have the connector to which you want
add wires? How many wires total in your task?
If you're considering a solder style, have you
compared your solder skills and tools with the
sizing of those pins and space between them?
I'm pretty sure that the $savings$ would have
a poor return on investment for the increase in
$time$ and $risk$ unless you're REALLY good
at working with those tiny spaces.
I personally wouldn't take on a soldering task for more
than a handful of wires.
out of that stuff?"
