BID weight from Aircraft Spruce
christoph.both(at)acadiau
PostPosted: Tue Dec 29, 2020 8:44 am    Post subject: BID weight from Aircraft Spruce Reply with quote
Hello,
I am looking for the correct BID cloth weight as used in the EUROPA kit.
This would be for an order from Aircraft Spruce in NA.
Thanks!
Christoph Both
C-GPEL
Wolfville, Nova Scotia Canada
rparigoris
PostPosted: Tue Dec 29, 2020 11:10 am    Post subject: Re: BID weight from Aircraft Spruce Reply with quote
Hi Christoph Rutan Fiberglass Cloths for Uni-Directional and Bi-Directional: https://www.aircraftspruce.com/catalog/cmpages/rutan.php?clickkey=76331 Ron P.
kingsnjan(at)westnet.com.
PostPosted: Tue Dec 29, 2020 2:17 pm    Post subject: BID weight from Aircraft Spruce Reply with quote
Christoph,
Cloths used on the Classic Europa are :-
Interglas
UNI = 92145 Plain weave 223 gm2
BID = 92125 twill 2x2 weave 280 gm2
www.pd-interglas.com
Biaxial = SP Systems XE481 235 gm2
Kingsley in Oz
On 30 Dec 2020, at 2:51 am, Christoph Both <christoph.both(at)acadiau.ca> wrote:
Hello,
Thanks!
Christoph Both
C-GPEL
PostPosted: Tue Dec 29, 2020 5:12 pm    Post subject: BID weight from Aircraft Spruce Reply with quote
Thank you very much !
Best,
Christoph
On Dec 29, 2020, at 15:11, rparigoris <rparigor(at)hotmail.com> wrote:
CAUTION: This email comes from outside Acadia. Verify the sender and use caution with any requests, links or attachments.
http://forums.matronics.com/viewtopic.php?p=499879#499879
PostPosted: Tue Dec 29, 2020 5:33 pm    Post subject: BID weight from Aircraft Spruce Reply with quote
Thanks Kingsley!
Much appreciated.
Best,
Christoph
On Dec 29, 2020, at 18:19, Kingsley Hurst <kingsnjan(at)westnet.com.au> wrote:
Christoph,
Interglas
Kingsley in Oz
> Hello,
> Thanks!
> Christoph Both
> C-GPEL
