Fwd: 912ULS fuel return line orifice size
peterz(at)zutrasoft.com
PostPosted: Fri Dec 04, 2020 4:44 am    Post subject: Fwd: 912ULS fuel return line orifice size Reply with quote
Looks like this is a very old question - and that Europa supplied larger restrictors.  Very odd.
http://forums.matronics.com/viewtopic.php?p=403137
---------- Forwarded message ---------
From: Pete Zut <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)>
Date: Fri, Dec 4, 2020 at 7:39 AM
Subject: 912ULS fuel return line orifice size
To: europa-list <europa-list(at)matronics.com (europa-list(at)matronics.com)>
Hi Folks,
I'm currently re-doing my fuel lines and configuration and have discovered my return orifice was made at 1/32" or 0.68mm which is twice the size of the spec'd rotax 0.33 mm or 1/64".  It may explain why whenever I turned the electric pump off the pressure would drop to near zero for a couple seconds before recovering to the expected 4-5psi.
Curious what size other folks are running? 0.33mm?
Cheers and thanks,
Pete Z.
rowlandcarson(at)gmail.co
PostPosted: Fri Dec 04, 2020 5:12 am    Post subject: Fwd: 912ULS fuel return line orifice size Reply with quote
Pete - yes, apparently the restrictor with the larger orifice supplied by the Europa factory was intended to reduce vapour lock issues. See my journal for 20th & 21st June 2013:
http://www.rowlandcarson.org.uk/aviation/europa_435/201306.php
in friendship
Rowland
To: europa-list <europa-list(at)matronics.com>
Hi Folks,
Cheers and thanks,
Pete Z.
| Rowland Carson ... that's Rowland with a 'w' ...
| <rowlandcarson(at)gmail.com> http://www.rowlandcarson.org.uk
| Skype, Twitter: rowland_carson Facebook: Rowland Carson
