RV10 Fuel Flow Gauges
docclv(at)windstream.net
PostPosted: Mon Aug 24, 2020 5:35 am    Post subject: RV10 Fuel Flow Gauges Reply with quote
Guys: We have built Two RV10s over the past 9 years N123CV & N784DC.
We fly both of them regularly. One INDICATES 14.5 gal/hr at 24 squared
(6500 feet) and the other 15.5 gal/hr. They are actually burning 11
gal/hr. We gust set each plane where we have found out where it needs
to be (the old thin to rough then smooth and watch the exhaust gas
temp). When we installed our Fuel sensors in each tank, we adjusted
them so that they read Empty when there is 3 gal in each tank, not that
you don't want to keep track of your fuel burn, but it is a little
reasuring to see the gas gauges wiggle a little when you rock the
wings. Doc
