Europa-List Digest: classic firewall
creightonious
PostPosted: Mon Jul 20, 2020 6:37 am    Post subject: Europa-List Digest: classic firewall Reply with quote
I had bad cooling problems on my 80hp Classic until I removed the second muffler and replaced it with a straight pipe.
Now, while it makes more noise, I can climb forever at 85kt in the Florida summer: 30C (at)1000ft on a relatively cool morning.
That chamber of the muffler blocks a lot of air.
Creighton 96EG. A-009
On Jul 19, 2020, at 02:35, Europa-List Digest Server <europa-list(at)matronics.com> wrote:
Today's complete Europa-List Digest can also be found in either of the
of the Europa-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 20-07-18&Archive=Europa
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 20-07-18&Archive=Europa
Europa-List Digest Archive
Total Messages Posted Sat 07/18/20: 2
Today's Message Index:
1. 10:41 AM - Classic firewall.... singleton vs steel & cooling. (Pete)
2. 11:01 AM - Re: Classic firewall.... singleton vs steel & cooling. (D McFadyean)
________________________________ Message 1 _____________________________________
Time: 10:41:50 AM PST US
Subject: Classic firewall.... singleton vs steel & cooling.
Hi folks,
I found on my classic that the composite firewall pretty well closed off the cowl
exit on my classic, with the muffler tucked up right against it.
I now wonder if the rudder pedal tubes and drive arms can be left on the engine
side of the firewall, and simply fabricate a stainless firewall sheet in line
with the upper firewall, leaving the rudder pedals, and all four engine mounts
on the engine side of the firewall.
I wonder how warm the pedals will get in the summer? My classic does have nicely
overlapping and tight stainless rudder pedal passthroughs.
Does anyone out there have a classic with a firewall as i have described?
Cheers and thx,
Pete
________________________________ Message 2 _____________________________________
Time: 11:01:41 AM PST US
Subject: Re: Classic firewall.... singleton vs steel & cooling.
I have a set up (the standard set up) much the same as your proposal.
The rudder pedals don't get hot.
Anything in the tunnel behind the steel firewall gets really hot, unless you have
a monowheel with lots of default circulating cooling air. Accordingly, I have
a 'fireblanket' on the back side of the steel, which reduces temperatures in
the tunnel.
Duncan McF.
> On 18 July 2020 at 18:39 Pete <peterz(at)zutrasoft.com> wrote:
> Hi folks,
cowl exit on my classic, with the muffler tucked up right against it.
> Cheers and thx,
> Pete
Creighton Smith
A 036
