With Flooded cells, at what discharge does damage start?
PostPosted: Sat Jun 13, 2020 7:48 am    Post subject: With Flooded cells, at what discharge does damage start? Reply with quote
At 09:09 AM 6/13/2020, you wrote:
Greetings,
This isn't a relevant question for modern aircraft but I think the membership of this list will likely know so I hope I don't bother anyone by posting here.
If you have a rarely used car with a traditional flooded cell lead-acid battery and keep an eye on the battery voltage, at what voltage should it be recharged to maintain a normal life? My old jeep has a small load while parked so the battery slowly drains and it is neither convenient for me to disconnect the battery nor keep a maintainer connected. If I charge it back up with my smart charger before the (nominally 70deg f) battery voltage drops to say, 12V will I still get full life out of the battery?
that would be a good milestone for initiating
a top-off charge. You could probably let it
go lower but keeping it above 12v will improve
longevity.
