Europa-List Digest: 2 Msgs - 05/17/20
karelvranken9(at)gmail.co
PostPosted: Tue May 19, 2020 6:43 am    Post subject: Europa-List Digest: 2 Msgs - 05/17/20 Reply with quote
David,Was it with afterburner?
Or did they forget the decimal?
Karel Vranken.
Op ma 18 mei 2020 om 08:38 schreef Europa-List Digest Server <europa-list(at)matronics.com (europa-list(at)matronics.com)>:
Today's complete Europa-List Digest can also be found in either of the
two Web Links listed below.  The .html file includes the Digest formatted
and Message Navigation.  The .txt file includes the plain ASCII version
of the Europa-List Digest and can be viewed with a generic text editor
HTML Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2020-05-17&Archive=Europa
Text Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2020-05-17&Archive=Europa
                           Europa-List Digest Archive
                     Total Messages Posted Sun 05/17/20: 2
Today's Message Index:
     1. 01:31 AM - Fastest Europa  (davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk))
     2. 10:25 AM - Re: Rotax 914 and Dynon comparability to calculate actual fuel u  (h&amp;jeuropa)
________________________________  Message 1  _____________________________________
Time: 01:31:33 AM PST US
From: davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)
Subject: Fastest Europa
I see that Flight Radar currently shows Europa XS GWIKI flying up in
Yorkshire at around 2000 ft at no less than 625 kts!
David Joyce, GXSDJ
________________________________  Message 2  _____________________________________
Time: 10:25:41 AM PST US
Subject: Re: Rotax 914 and Dynon comparability to calculate actual
fuel u
From: "h&amp;jeuropa" <butcher43(at)att.net (butcher43(at)att.net)>
Tony,
A couple of maintenance ideas.
We have FloScan transducers, not red cube.  A couple times there has apparently
been some small debris caught in them resulting in unusual readings.  The guys
at GRT gave us the tip to reverse the flow thru each one to clean it.  So ours
are mounted on the stbd side footwell where we can easily get to them and switch
the hoses to reverse the flow.
We found that our FloScan transducers work more reliably when mounted to a solid
surface, not suspended in a fuel line.
Finally, the pumps for a 914 have a small filter screen on the inlet.  You can
carefully remove these and we do every year during inspection.  Often there is
a little debris in there.  So plan your installation to make removing the pumps
not too difficult.  But be careful, we haven't been able to find a place to
purchase the screens if you destroy one.  You have to purchase the whole pump!
Jim & Heather
http://forums.matronics.com/viewtopic.php?p=496422#496422
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
