Sorcerer to AeroCruze replacement
docclv(at)windstream.net
PostPosted: Wed Apr 29, 2020 9:36 am    Post subject: Sorcerer to AeroCruze replacement Reply with quote
David: Thanks for the tip. My biggest concern in replacing my Sorcerer
if TruTRak doesn't come through is that the servos are compatible and
the wiring harness doesn't require major changes (That is a dreaded
thought to get under the panel and rewire). When I talked to Stephen
Gock at TruTrak several weeks ago he implied that the servos were
compatible on most TruTrak units. Donny Hernandes Says the Experimental
TruTrak units are now handeled in Edmo, WA and recommended I talk to a
Harold Christiansen in WA if he can't get some answers for me. I'll
post my outcome for our followers. What a let down from TruTrak.
