Z11 revision needed?
ceengland7(at)gmail.com
PostPosted: Wed Jan 22, 2020 4:59 pm    Post subject: Z11 revision needed? Reply with quote
Hi,
I'm in-process, updating my purchased RV6 electrical system. It was
loosely based on the AEC Z figures, but needs updating for several
reasons. This is a relatively simple, 1 battery/1 alternator system with
1 mag & 1 Lightspeed ignition, and Bendix style injection.
While consulting the Z figures to rearrange loads to various buses, I
noticed the boost pump feed on the Endurance bus is shown as 3A. No
doubt Z11 was created when 'simple' planes had fueled delivered by
carbs, but Bendix style injection has become quite common on RVs & other
Lyc powered homebuilts.
The issue I'm raising is that virtually all the commonly used 'boost'
pumps (actually *backup* pumps) in use with Bendix style fuel injection
these days have at their core, an automotive fuel injection pump which
draws a minimum of roughly 6A continuous, with no doubt, considerably
higher startup inrush current. With only a 7A fuse (and 16 Ga wire)
feeding the Endurance bus, This seems quite marginal. Even if we assume
minimal actual loads from the other active devices on this bus, the need
to activate the backup fuel pump could result in getting 'close to the
edge' of voltage drop ratings for 16 Ga wire, and if we are already
operating in Endurance mode, could easily take out the 7A fuse supplying
the endurance feed to the bus.
Should wire sizes and fusing be increased on this drawing, as has been
done on some of the other drawings where the backup pump load is shown
as 10A?
I should note that several other Z figures also show 7A protection and
16 Ga wire to the Endurance bus, but most of the others don't define any
loads on that bus. Assuming that a high pressure pump is needed in the
a/c, it would need to be on the Endurance bus and, it seems to me, the
bus would need a more robust supply.
Even with everything (including the alternator) on line, having to add
the backup fuel pump load to the other loads on that bus will push
voltage drop on the feed wire past the typical 10% limit.
Charlie
PostPosted: Thu Jan 23, 2020 8:14 am    Post subject: Z11 revision needed? Reply with quote
At 06:56 PM 1/22/2020, you wrote:
--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com>
Hi,
I'm in-process, updating my purchased RV6 electrical system. It was loosely based on the AEC Z figures, but needs updating for several reasons. This is a relatively simple, 1 battery/1 alternator system with 1 mag & 1 Lightspeed ignition, and Bendix style injection.
While consulting the Z figures to rearrange loads to various buses, I noticed the boost pump feed on the Endurance bus is shown as 3A. No doubt Z11 was created when 'simple' planes had fueled delivered by carbs, but Bendix style injection has become quite common on RVs & other Lyc powered homebuilts.
The z-figures are ARCHITECTURE EXAMPLES to
aid in fabrication of a power distribution
appropriate to YOUR project.
The issue I'm raising is that virtually all the commonly used 'boost' pumps (actually *backup* pumps) in use with Bendix style fuel injection these days have at their core, an automotive fuel injection pump which draws a minimum of roughly 6A continuous, with no doubt, considerably higher startup inrush current. With only a 7A fuse (and 16 Ga wire) feeding the Endurance bus, This seems quite marginal. Even if we assume minimal actual loads from the other active devices on this bus, the need to activate the backup fuel pump could result in getting 'close to the edge' of voltage drop ratings for 16 Ga wire, and if we are already operating in Endurance mode, could easily take out the 7A fuse supplying the endurance feed to the bus.
This is what the LOAD ANALYSIS is for . . . it
should be the very first document you craft in
the planning for your airplane. This document
provides the foundation for ADAPTING a z-figure
to your specific needs.
Should wire sizes and fusing be increased on this drawing, as has been done on some of the other drawings where the backup pump load is shown as 10A?
I should note that several other Z figures also show 7A protection and 16 Ga wire to the Endurance bus, but most of the others don't define any loads on that bus. Assuming that a high pressure pump is needed in the a/c, it would need to be on the Endurance bus and, it seems to me, the bus would need a more robust supply.
Even with everything (including the alternator) on line, having to add the backup fuel pump load to the other loads on that bus will push voltage drop on the feed wire past the typical 10% limit.
Size ALL circuit protection to the anticipated
loads along with considerations for the use
of fuses that need 25 percent headroom for
steady loads . . . EXTRA for loads with inrush
currents. Fuses can be 'hammered' to failure
by seemingly ordinary circumstances.
Fuses are first sized to wire then upsized to
grunt transients. This consideration is above an
beyond any decisions about architecture. What
your involved in now is the first phase
of failure mode effects analysis based on a
knowledge of system components.
Good on you my friend.
