Paintball/scuba bottles
greg.barnhard@gmail.com
PostPosted: Sun Sep 22, 2019 6:35 pm    Post subject: Paintball/scuba bottles Reply with quote
I have a question for those who carry the smaller portable paintball gun/scuba pony bottles. I’m looking at getting something like that to take with me on trips for the obvious reasons.
I’m curious to hear how you have them set up. What size bottles are you carrying? I’ve been looking at the 60ish cubic inch paintball bottles. My other question is in regard to the plumbing from the bottle to the airframe air refill port. What kind of regulator are you using on the bottle? Is it just a stock regulator that comes with the bottle? How do you meter the air out of the bottle so it doesn’t fill the aircraft tank too quickly? I guess my main question is piece by piece what kind of fittings are you using starting from the bottle to the Airframe refill port fitting?
Thanks in advance,
Greg
Ttail
PostPosted: Sun Sep 22, 2019 9:21 pm    Post subject: Re: Paintball/scuba bottles Reply with quote
I run a 2L bottle at 4500psi. I just use the stock paint ball req. I very very slowly just crack the reg its very controllable.
I run a Stauf fitting from the Paint ball outlet. Stuaf fitting goes into 1/4"npt. this runs through some very high pressure certified hose to a Baynot fitting
This shows the Connections using a 1.5L bottle before I moved up to 2L bottle. There is a pressure bleeder on the end near the bayonet fitting to bleed residual line pressure before disconnect.
Second image shows size comparison between 2L v 1.5L bottles
1906
PostPosted: Sun Oct 06, 2019 7:36 pm    Post subject: Re: Paintball/scuba bottles Reply with quote
Ttail, does someone sell this entire kit? I have not seen those fittings or fill port before.
Ttail
PostPosted: Sun Oct 06, 2019 8:57 pm    Post subject: Re: Paintball/scuba bottles Reply with quote
The Stuaf fittings are available commercially in Australia. The Adapter to go on to the fill port we had made up in a CNC shop. So its a case of shopping for what you want then assembling it. In my case I was lucky enough to be put in contact with a Gent that deals with pneumatic stuff for the railways.
PostPosted: Mon Jan 06, 2020 3:05 pm    Post subject: Re: Paintball/scuba bottles Reply with quote
How much of a refill do you get with your portable bottles?
Greg
pennington.construction.i
PostPosted: Mon Jan 06, 2020 3:14 pm    Post subject: Paintball/scuba bottles Reply with quote
You have to compare your on board bottle volume and pressure.
Compare that to the volume and pressure of the scuba tank.
That will tell you what you want to know.
Mark
N621CJ
On Mon, Jan 6, 2020 at 6:10 PM greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com) <greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com)> wrote:
--> Yak-List message posted by: "greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com)" <greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com)>
Greg
http://forums.matronics.com/viewtopic.php?p=494181#494181
br> fts!)
r> > rel="noreferrer" target="_blank">http://www.matronics.com/contribution
          -Matt Dralle, List Admin.
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
PostPosted: Tue Jan 07, 2020 2:09 pm    Post subject: Re: Paintball/scuba bottles Reply with quote
I’m not 100% sure if my math is correct. I’d like an efficient size to carry with me and without buying multiple sizes and testing I won’t be certain.
Greg
PostPosted: Tue Jan 07, 2020 2:20 pm    Post subject: Paintball/scuba bottles Reply with quote
Greg.
Give me a call offline if you have any questions. I would be happy to talk with you.
Mark
894 399 4224
I am in Richmond VA.
On Tue, Jan 7, 2020 at 5:13 PM greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com) <greg.barnhard(at)gmail.com (greg.barnhard(at)gmail.com)> wrote:
Greg
http://forums.matronics.com/viewtopic.php?p=494192#494192
br> fts!)
FORUMS -
WIKI -
b Site -
PostPosted: Tue Jan 07, 2020 2:51 pm    Post subject: Paintball/scuba bottles Reply with quote
Greg
I gave you the wrong number.
804 399 4224.
Mark
Greg
br> fts!)
FORUMS -
WIKI -
b Site -
